LinkedIn IET Switzerland (To Promote IET My Communities)
Please check out the LinkedIn IET Switzerland group, which I just set-up to advertise future events like the AGM / Crisis Command Workshop. If the following link doesn't work, just go into LinkedIn groups and search for "IET Switzerland". Just to be clear, this is not to replace or take anything away from using My Communities. It's just intended as a pointer to My Communities. Anyone fancy setting up the same in Xing? I can look at that if there are no takers..
http://www.linkedin.com/groups/IET-Switzerland-4870366?gid=4870366&trk=hb_side_g
