Malaysian IPRA - International Professional Registration Advisors
In case you need to now more about Professional Registration you may contact the following:
Please find a list of IPRAs in Malaysia, you may also search for the updated list through the link at the IET website:  http://www.theiet.org/membership/profreg/find-advisor/searchadvisor.cfm
Local Network Advisors, Malaysia Network
Name    Category        Local network
Yaacob , Professor Mashkuri     CENG    E & S.E Asia:Malaysia
Lee , Dr Ching  CENG    E & S.E Asia:Malaysia
Punchihewa , Dr Amal Gardiyawasam       CENG    E & S.E Asia:Malaysia
Ramachandaramurthy , Dr Vigna   CENG    E & S.E Asia:Malaysia
Goh , Dr Hui    CENG    E & S.E Asia:Malaysia
Fam , EUR ING Ir. Jimmy CENG    E & S.E Asia:Malaysia
Lim , Mr Yew Kee        CENG    E & S.E Asia:Malaysia
Chris Chew
    I am interest in application of PE
  • Hi Chris Chew,
    I must get a Professional Advisor from IPRAs list in order to get PE (CEng) in Malaysia?
    YY
  • I hope you have found your ways to Professional Registration.
    If there is anything you need to know please contact us.
    Chris Chew
    Good evening,can I be an advisor  and what are
    the requirements.I am still disappointed with I.E.T as  I am
    not able to access the website.
    Please help.
    Thank you.
    With regards,
    Ir.S.Jagathisen.
    HI Dr Jagathisen
    Regarding IPRA requirements:  Please find the details at this link:  www.theiet.org/.../ipra.cfm
    Regarding your question about logins issues, can you let me know the below to check with IT support:
    1) Can I assume you have no problem logging in the IET website:  www.theiet.org and only have problems logging in Engineering Communities:  https://communities.theiet.org/home  ??  Correct me if I am wrong.
    2) What error message you see (display on the screen) when you login?
    IT support will need the above in order to check for you the login issues.
    Many thanks!
    My problem is to reset password,as I.E.T have come
    up with new system my old password cannot be used.However I
    followed as required and time I set the password as required the
    web page cannot be login.I sent a number of requests to I.E.T and
    each time they reset I can't login.
    Hope you could help.
    Thank you
    With regards,
    Ir.S.Jagathisen
    HI Dr Jagathisen
    I am now looking into this for you, may ask you some questions later about the below in order to get the right information for you.
    Winnie
