I have a 230v extractor fan with a long moveable "trunk" for removing fumes from a welding area. I have fitted a normal 230v motor starter. The trunk has an inbuilt cable with a pair of 24v ac LED worklights and a switch on the end. My customer wants to be able to turn the fan on/off from the end of the trunk using a second switch already fitted to the inbuilt cable.
My plan is to change the motor starter contactor to one with a 24v coil so that I can use the existing built in cable, power supply and switch. The switch is just a one way switch so I think I will need a DPDT relay to provide the function of remote start and stop buttons.
Am I over-thing this or is there an easier way?
Dave
