Rail Strikes and Cycling to work.
Londoners are being threatened with strikes for higher fares but why not cycle to work and be healthier as an option.
If the railways are causing an inconvenience to your normal travel then in this beautiful weather why not get your bike out ; blow up the tyres and oil the gears.
Off you go but the traffic is a problem so chose your route to be safe from cars by back-routing through residential roads.
Boris bikes could be used if available and the government should be pressurised to build cycle ways along the sides of all existing railway tracks into London.
Starting with Clapham to Victoria and Waterloo to give instant access to the city.
Later to be extended to Wimbledon and beyond.
|DO IT NOW....
