Converting a TT earthing system to TNS System
Hi
I am a control systems engineer who dabbles in the electrical side of the job now and then as the job demands. I have come across an issue which I cant find much help online.
One of clients is located in Japan and they have informed very late into the build that they have TT earthing system on site, instead of TNS system as they have previously told us.
Our product is designed for TNS earthing system and therefore a significant amount modification will be needed to make the product work safely with a TT system. Since it was too late and expensive to make the changes to our system, the client has agreed to look in the possibility of providing our system with a TNS supply by converting the existing TT supply on site.
They have transformer on site which they are using to supply to our system. The proposal is essentially to connect earthing of the secondary of the transformer to our system and use that as PE. Is that a viable solution? I cant believe that it can be this simple.
Can you please advise any other considerations to be made while making the decision.
Thank you very much
