New Proposed Sizewell C
It is being bulit just above sea level on a sandy coast. Is this wise?
A new nuclear power station needs a vast supply of water. But where will Sizewell C get it from? | William Atkins | The Guardian
  • For those unfamiliar:
    Lowestoft is part of the 44-station UK National Tide Gauge Network, maintained by the Environmental Agency.
    The NTGN is in turn a member of the Global Sea Level Observing System (GLOSS) which is maintained by UNESCO Intergovernmental Oceanographic Commission. The GLOSS core network consists of around 300 measuring stations. The real time data are available through the Sea Level Station Monitoring Facility at VLIZ in Belgium. Collection, publication, analysis and interpretation is the responsibility of the Permanent Service for Mean Sea Level (PSMSL), established in 1933 at the National Oceanography Centre at the Uni Liverpool. The Intergovernmental Oceanographic Commission Group of Experts meets every two years to publish a report. The experts are named on the respective WWW sites and the reports available on-line. PSMSL and GLOSS publications may be found at https://www.psmsl.org/train_and_info/training/gloss/
    Contrary to what has been said above, the MSL has been rising recently. A graph showing the rise from 1700 to 2100 can be found at Figure 7.1 of J.T. Houghton, Global Warming, Fifth Edition, Cambridge U.P. 2015. The figure from 1700 is composed from paleo sea level data; for about the last 100 years from tide gauge data and altimeter data; and the future projections from models using the RCP 2.6 and RCP 8.5 scenarios.
    The PSMSL WWW page reports the 2013 IPCC WG1 statement that
    "It is very likely that the mean rate of global averaged sea level rise was 1.7 [1.5 to 1.9] mm/yr between 1901 and 2010, 2.0 [1.7 to 2.3] mm/yr between 1971 and 2010 and 3.2 [2.8 to 3.6] mm/yr between 1993 and 2010. Tide-gauge and satellite altimeter data are consistent regarding the higher rate of the latter period"
    Since these data are based on actual measurement, AFAIK they have not changed since the 2013 statement.
    But our bot claims otherwise. On the apparent basis of data that are included in this dataset. It is all but certain that it will not be able to explain its deviation.
  • https://ntslf.org/tgi/portinfo?port=Lowestoft
    The device cannot be completely accurate being attached to such a structure as it is.
    Where's the allowance for movement.
  • Let's follow the train of (if it may be so called) "thought" here.
    Proposition 1: Sea level rise is constant
    Question: On the basis of what data?
    Proposition 2: On the basis of data from Lowestoft
    Remark: The data from Lowestoft are part of the NTGN, which is in turn part of the GLOSS, and it is on the basis of the GLOSS that the sea level rise is judged. And the GLOSS data do not show constant rise, but increasing rise (in three periods from 1901 to 2010).
    Proposition 3: The Lowestoft data are maybe not accurate.
    So let's put Propositions 1-3 together: Sea level rise is constant, on the basis of Lowestoft data, but they are maybe not accurate.
    If someone said that to me in an exam, I would ask, first, why they were making an unqualified assertion on the basis of data they don't trust. (There is no good answer to this question.) Then, second, I would ask how maybe more reliable data can be gathered. The obvious answer is: use a wider collection of data. I would remark that that has been done since 1933 in Britain and 1960 internationally, and those datasets have been analysed. Third, I would ask how often they are nominally analysed? The answer is: every two years. Fourth, I would ask what those analyses have shown. The answer is above.
