Overhead cranes braking systems.
An overhead crane’s 3-phase slip ring motor can single phase while operator is hoisting/lifting a load. This has a potential of the load suddenly dropping to the floor crashing the operator or damaging equipment. From the principle of operation of a 3-phase induction motor, if it single phases whilst running, motor keeps running (but won’t restart if it trips until single phase problem is solved) until it trips on protection, eg, single phasing, fuses blowing, phase imbalance, winding temperature high etc. This therefore means that the motor keeps running but doesn’t have enough torque to hold the load.
(Obviously during normal operation, the brakes are released but fail safe when operation is cancelled or stopped).
How best can such a scenario be avoided or how can it be stopped from happening since overhead cranes are used everyday in our industries.
  • Not really my areas, but to get the discussion going...
    Sounds to me like the motor will have stalled - so will have stopped (at least momentarily as the load transitioned from going up  to going down) in any event wouldn't have kept running in any normal sense.
    The safety systems sound very dubious to me - phase monitoring relays are reasonably cheap and readily available - so I would have thought the machine should have gone into shutdown as soon as one line dropped - probably cutting off all supply to the motor and allowing the brakes to be applied.
  • It will be an odd design that is neither self breaking (so lowly geared that the maximum design load does not spin the motor) - smaller winch designs are like this, nor does any kind of brake come on under spring pressure if there is a power loss. Unless the loads are so small that no injury could ensue, the brake release circuit needs to be interlocked to the motor power - so if there is no power- the brakes go and stay on, I'm surprised it is not like that.
    Where in the world are you ? I ask because in the EU that would be a failure to meet machinery directive.
    PS
    consider this extract from
    EN 15011:2011 (E)
    5.4.2 Braking systems
    5.4.2.1 General
    All power driven motions shall be under the control of a braking system at all times. The braking systems shall be such that movements can be decelerated, the motions can be held and unintentional movements avoided.
    The systems shall be capable of bringing a fully loaded crane to rest from the highest speed it can attain.
    5.4.2.2 Mechanical service brakes in power driven motions
    Only power released brakes shall be used and they shall maintain their ability to stop the motion, at all times. Brakes shall be protected from the ingress of substances within the environment, which are likely to have a detrimental effect on the performance of the brake.
    NOTE Where electrical braking systems are used, the associated mechanical brake is only subjected to limited use. Special attention therefore may be neede d to maintain the required mechanical braking torque, see 7.3.3.
    Mechanical service brakes shall engage automatically in the following cases:
    the control device returns to its neutral position;
    the power supply to the brake is interrupted;
    the emergency stop device is activated
    etc.
  • So are the cranes breaking because they aren't braking? This is a case where correct spelling makes all the difference.
  • Thanks Andy. You mentioned other protection systems like 3-phase monitoring devices and stalling protection.
  • Thanks Mike for the response and extracts from EN 15011:2011 (E), I will read more on the subject.
    The Issue of geographical location, however, doesn't really matter because machines anywhere in the world still fail with all the required protection systems in place, that's why we re-engineer, redesign and maintain systems based on our daily experiences and changes in technology, standards and statutes.
  • Thanks Simon for the observation. The question is on braking systems.
  • Region  can  matter though - US regulation of cranes through OSHA is lot less prescriptive in this regard, and machines coming to Europe from the US that only meet the US rules have to be modified with additional safety features before they may be used here I'm not sure if that includes power failure emergency braking because by they get here, they certainly have it.
    I know more detail about a similar problem with things like IR curtains on metal cutting machines that get added to imported models to detect if a hand is about to be put into the moving cutters - not needed over there apparently so not fitted.
    It would be quite nice if the standards were indeed the same, but they are very much not.
    (and at least one US maker knows it.. they seem to be advocating a tightening of the US rules  and in the mean time suggesting that discerning US customers should request the EU compliant model - which is interesting)
    I am not sure about other parts of the world, I suspect that there are places laxer still in the far east.
