Defining if your equipment falls under WEEE Directive (2012/19/EU)
Hi There,
My company is undergoing a CE review and we have engaged with a consultancy who have found a few minor gaps in our tech file and processes (so overall a worthwhile process), however they believe our manufactured equipment comes under WEEE and RoHS.
We make industrial equipment shipped around the world, with a very small installed base in the UK. our equipment:
  • Is only sold to industrial users for incorporation into product filling lines
  • Is a mechanical action machine that cuts, forms and delivers caps to filled bottles
  • The machines are Electronically controlled via HMI / PLC, utilising servo and vfd driven motors from a control cabinet or supplied panel
  • The equipment is wired to plant mains (usually 400V 30A feed)
  • The machines are free standing but bolted down and attached to the filler / sealer via the cap delivery chute
  • The machines are approximately 2 - 2.5m tall, and weigh between 0.5 to 1 Ton
  • Our machines do not have an expected lifecycle (we still have equipment supplied in the 1970's in production)
  • We have not supplied new machinery to a UK site for over 6 years, majority has been outside of the EU as final destination
As such, we did / do not believe the machine comes under WEEE.
All Electrical / electronic components used are RoHS / WEEE / CE compliant from major manufacturers such as Siemens, AB, Wenglor etc)
All parts / materials used are RoHS compliant, but we believe the machine itself does not come under RoHS as a whole.
Anybody able to shed light onto which side we fall onto?
  • Hi Craig,
    Hmm. It sounds from your post as if the key issue is going to be whether your equipment can be counted as exempt because it counts as
    "large-scale stationary industrial tools"
    "large-scale fixed installations which perform specific industrial operations"
    https://www.gov.uk/guidance/regulations-waste-electrical-and-electronic-equipment
    and
    "large-scale stationary industrial tools and large-scale fixed installations"
    https://www.gov.uk/guidance/rohs-compliance-and-guidance
    I think I'd probably give the same advice as your consultant (in fact I did give this advice last year to a client in a roughly similar position to yours) - it should be really easy completing the WEEE and RoHS compliance (since fundamentally you're just going to state that the sub-assemblies are and pass the WEEE measures on), so it's probably less risk doing that than someone at some point deciding that they are not "stationary / fixed" which would then land you in trouble. Having always worked in the supply of equipment for fixed installations, with typical service lives of 25 years plus, I've still always found it's easier to just do the WEEE and RoHS compliance than to try arguing your way out of it.
    But that said, yes it would be reasonable to go back and at least ask your consultant why they consider your equipment doesn't meet those criteria.
    Unless of course you are definitely not going to sell it into the UK or EU again, in which case of course you don't need to.
    Hope that helps a bit.
    Thanks,
    Andy
  • Hi Craig & Andy, Thanks for sharing the experiences. I supported both yours' comments. The other considerations are the cost & time spent to develop an equipment to meet the customer specifications and price agreed. Before signing off the purchase agreement, Often, the equipment supplier would like to know and document where or which countries these equipment will be installed and if customer required an independent certification body to certify this equipment to meet the specific install country standards based on their multiple install bases or factory locations. Example, an equipment designed and developed to meet the EU/CE standards might not pass the US NFPA79/uL508a requirements. My experiences on equipment Design/development are to choose components that meeting IEC Standards, against it depends on the total equipment cost, some customers may required the very first Production equipment to be 3rd. party or independent certified body to audit and buy-off to meet the install base or country standards, the subsequent similar model should just be built Copy-Exactly the same standards to the specific install country.
    Thanks.
    KimL
