Heat pumps and the media.
So when we reach the 2030s, ordinary central heating boilers, as we know them today will be banned. We will need to replace gas boilers with heat pump systems - expensive at the outset. And that is not all. The water temperature produced by heat pumps is not as high as that produced by gas central heating boilers. So we will need to replace our radiators with larger and thicker ones, to gain the same heat from cooler water. This it turn means that we will need stouter pipes to feed those radiators, so the piping will need to be replaced - even more expense and considerable disruption.
That at any rate is the gloom prophesied by the news media. I decided to look beyond the media and see what alternatives are available.
I started by examining the present alternatives. The media seem to focus on the common idea of a central heating system, with a central boiler and radiators. Our present house has such a system.
In our previous house, the central boiler heated air, which was sent to the various rooms via ducts. Individual rooms could be shut off if heating was not required therein. An advantage of this system is that if a room is suddenly needed, opening the air shutter causes the room to heat up very quickly. The benefit of the heat can be felt in less than five minutes and the room can be comfortably warm in about 15 minutes. Radiators cannot respond as quickly as this. Their thermal mass means that they take time to warm up before they begin to deliver heat in appreciable quantity, and they rely on natural, instead of forced, circulation. Conversely, if the room becomes too hot, the heat from and air duct can be shut off immediately, whereas a radiator continues to give off unwanted heat while it cools. A disadvantage of ducted air is that the air flow can be accompanied by a hissing noise, which can be intrusive, though there are ways to suppress this.
Our house previous to that had gas fires in fireplaces. These could produce noticeable heat quite quickly and get the room quite warm and cosy in time. They did not do much for the hall and landing areas, however. We later addressed this by having a through-the-wall-flued gas convector heater fitted, and this was very effective.
So here are three ways to heat a house. Can we draw parallels with heat pump technology?
The system using radiators has been well-publicized. I found some very useful information from the Energy Savings Trust.
energysavingtrust.org.uk/.../
If heat pumps are limited in respect of how well they heat water for radiators, why do things that way? Why not pump the heat directly to air instead?
It seems that this option could be possible, especially where ducted air heating is already installed. It would require the main equipment to be on an outside wall; however; this will not always be the case for gas fired systems. If a ducted air system is not already installed, the practicality of installing one would depend on the size and layout of the house. A bungalow would usually take such an installation easily; the ducts could run through the roof space and serve nearly all of the rooms. For a house of more than one storey, installation would be less easy. Ideally, it could be installed easily in a new house as part of the building process. Bear in mind that water has a much larger thermal capacity for conveying heat than air. Also it is more effective in transferring heat in a heat exchanger. We need hot water for taps, so provision would be needed to take off some of the pumped heat for this purpose. However hot tap water is usually heated to about 60 °C, whereas radiators need about 75 °C, so this could be achievable. Another advantage of this system is that it could operate in reverse in hot weather to provide cooling. Radiators cannot do that.
Could there be an equivalent for an individual through-the-wall gas heater? I do not see why not. Through-the-wall cooler units have been used in hot countries for many years. Could not these be adapted as heat pumps? I think they could be very cost-effective, because they would avoid the upheaval of replacing radiators and associated piping. A good sized fridge-freezer can be bought for around £400, so why should these, mass-produced, be more expensive? Around eight could serve a 3-bedroomed semi.
The BBC recently ran a program about heat pumps, interesting and instructive on some points, but again it focused on radiator systems. I imagine that in the coming years all three systems I have described will be employed, sometimes in combination, according to the type of premises where they can be installed. Engineers will find cost-effective measures, as always. What do to others think?
  • I also watched the same program, and it looked into hydrogen as a possible option and installed it in a street in Whitby against the residents’ wishes. I think that in the coming years, all three systems you described will be applied, sometimes in combination, depending on the type of premises where they can be fitted. Engineers will come up with cost-effective solutions, as they always do.
  • Thanks, AMK. That's Whitby, Ellesmere Port - not the better-known fishing town in North Yorkshire. Around ten years ago, Hydrogen was seen as the saviour of the planet. The great thing about heat pumps is that they are effectively around 300% efficient; i.e. the energy required to pump the heat is only about a third of the electrical energy that would be required to be converted into heat energy. Hence to convert electrical energy into hydrogen and then burn that hydrogen does not make economical sense, even before you take into account the additional costs of compressing the hydrogen and transporting it to the points of use. I understand that the experimental scheme at Whitby used hydrogen sourced  from natural gas. This could possibly be a cost-effective process if the hydrogen were to be collected and distributed from that site. Bear in mind however that natural gas is a fossil fuel.
    I understand the Whitby scheme is coming to an end but there is a similar scheme in Redcar, North Yorkshire, still progressing. I wish it success but I don't anticipate that it will produce hydrogen in sufficient quantities to be applicable on a large scale, though no doubt it will be usable and economical for some specific purposes.
    This could be a whole separate topic - other views most welcome.
  • Most UK houses aren't fitted with ducting for warm air central heating.  It was briefly popular, but retro-fitting to to existing houses isn't going to be terribly practical.  And air-to-air systems won't heat your hot water tank.
    Fitting the house with many smaller air-to-air systems is probably not that hard.  They would be similar to the wall-mounted air con units found in small offices.  But then you get hit by the requirement for planning permission.  The government has allowed a limited permitted development examption for one heat pump per house.  Any more than that, and you need planning permission.  And you will have to show that the noise of all your heat pump units won't affect the neighbours.
  • Thanks for your thoughts, Simon. I agree - a fanned-absorber unit under nearly window of each house is not going to look attractive. But then we have a similar aesthetic problem right now with solar panels. A group of these making maximum use of the area of a pitched roof has a jagged profile which jars with the roofline. So far there has been little interest in making these in shapes other than rectangular, to blend more pleasantly.
    In general. planning authorities are good at coming up (sometimes quite reasonably) with objections, but less good at coming up with ideas of how to improve designs. It is up to engineers to make designs more attractive. A possibility with a self-contained unit could be to try to get as much as possible of the workings inside the house, so  only a couple of air ducts would need to project to the outside of the wall.
    I think that in time engineers will come up with improved designs, and overcome some of the technical drawbacks, e.g. limitations on radiator temperature, also bring down costs. If engineers and planners could talk to each other more, that would be a real help.
  • The other side of this is insulation - if you can keep the heat you spend energy to pump in or out from sneaking back via some other path, this is a large and (once installed), low maintenance  part of the solution. All modern housing, post 1984 will have some sort sort of insulation in all parts of the UK, and in some areas quite a bit prior to that, perhaps as far back as  1967.
    The problem is that we have a lot of much older and rather crummy  housing some of which needs a serous upgrade.
    One insulation and ventilation controls are properly done, then the choice  of heating  or cooling method is a lot less critical, as whatever you do, there will be a lot less of it needed..
    Unpopular though it is, solid wall cladding inside or outside will have a big role to play.
  • Having completed a lot of the required industry and manufacturer training in heat pumps and subsequently realizing the full extent of the work necessary to most existing properties I have come to the realization that heat pumps will only really take off once efficient high flow temperature machines are mass manufactured. I read recently that this technology is being developed with a Scandinavian firm using Helium as the refrigerant allowing flow temperatures of 80c with the same electrical input as todays market models.
    Once these are available as literally plug and play units where by an installer can remove the existing boiler and re-route the flow and return to the exterior heat pump with minimal disruption to the property with no upgrades to the existing radiator system, only then will the great heat pump revolution get underway. Until then it's a false dream.
  • Getting 80C output with the same COP as current heat pumps requires something that's pushing very close to a theoretical perfect heat pump.  Our current ones aren't even close to that.
    You will always get better efficiency by lowering the output temperature.
  • I remain to be convinced that conventional heat pumps are the green saviour.  Leaving aside the issue of decarbonisation of the grid, there's the problem of refrigerant loss which has a catastrophically bad green house effect.  I'm troubled at the amounts that get lost from the commercial refrigerant-based systems I manage and until that's solved heat pumps can only be a partial solution.  It might be that better insulation and direct electrical heating provides a cheaper and greener solution.
