Space Weather Affects Railway Signalling
There is an article in E&T Suggesting that railway signalling can be significantly affected by solar storms.
https://eandt.theiet.org/2023/12/11/space-weather-could-trigger-signalling-failures-uk-railways-research-suggests
The EMC environment around electric railways is already pretty harsh and the signalling systems are designed to cope with this.
The article does not reference the paper which is here:
https://agupubs.onlinelibrary.wiley.com/doi/10.1029/2023SW003625
It appears to relate to a very simple track circuiting system and suggests that wrong side failures are potentially more likely than right side failures.
Are the assumptions in the paper reasonable or are there other mitigating systems that have not been taken into account?
  • This is an interesting article. The voltage gradients are quite low compared to the normal EMC fare, only a few volts per km (millivolts per metre) across the surface of the planet., but unlike most EMC/EMP problems that are transient surges or bursts of oscillation, while this sort of effect is so slow as to be effectively a near static DC offset across the earth surface,
    ( For mental  calibration purposes. with EMC immunity tests, we look to illuminate the test object with  RF signals of whole volts per metre, sometimes tens to hundreds of them before things stop working. By contrast a few microvolts per meter are fairly sensible radio signal magnitudes to expect  at the limit of range of a radio telemetry link. )
    The effect of this such that if you hammered in a pair of earth spikes a km apart and ran your meter leads between them you would see a few volts, probably a DC level changing slowly during the day. as the earth rotates. I am not sufficiently expert in railways to comment if the assumed thresholds or mechanisms for various fault types are credible or not.
     I can imagine problems with larger LV installations and  certain odd N-E situations and  RCDs however.
    (The earth is moving both round the sun, and round it own axis, in a significant but more or  less static but non-uniform magnetic field, and acts rather like a 'wire' moving in the magnetic field within a generator - now if the current in the wire and in the planet followed the same spatial path perfectly, there would be no voltage, nor if the field was non-divergent, Neither or these  is true so you see the difference in the voltage seen in the surface wire, and the voltage seen in the average of all ground paths.).
    Radio things are not affected by this sort of near DC effect, but some systems are well and truly nobbled by the change in density of the earths ionosphere that occur with solar storms, and  that does usually occur at the same time.
    (From the perspective of the radio it is as if the top of the sky turned  silver and reflective  at frequencies where it used to be transparent, and at some frequencies where it used to be reflective, it turns pitch black. Those of us with ham radio licences rely on that shifting reflective layer to bounce signals round the planet on HF, but it only works at the right time of day and then with the right ionospheric conditions - and is very sensitive - in some ways HF comms is the canary in the coal mine, and measuring propagation by firing RF up and looking at the echoes (ionosounding) is one very sensitive way these events are monitored.(These results drive some predictions http://www.infotechcomms.co.uk/propcharts/december/ select a 24 hour time- UTC  and a frequency, and see where signals get to change by the hour...)
    From a wiring perspective, probably insulated line pairs and transformer coupling is your friend, although there is precedent in the US and Canada for their grid transformer cores being saturated by the DC flowing in the ground-neutral path  - much like the blinding of an RCD by DC Then large currents flow, and fuses operate. The UK has  shorter transmission line distances and also does  not t distribute its HV neutral which reduces the severity of this sort of effect.
  • For context, I'm a signalling industry consultant (and for many years was "the" consultant) to the Rail Safety and Standards Board specifically on EMC compatibility of track circuits, a (somewhat specific!) field I've found myself involved in for over 30 years now. So I will be reading this paper in detail with interest.
    In principle, yes we get concerned about any additional sources of electrical energy that can interfere with, particularly, d.c. track circuits, as these can in theory result in an unsafe condition (wrong side failure). Modern track circuits require complex signals where it becomes increasingly unlikely that interference will be credibly detected as the "correct" track circuit signal, but d.c. track circuits only need d.c. And crucially, in the worst case of environmental conditions, they can only need a relatively small additional level of energy to trip them into false detection of a clear track. As an example, a bugbear of the industry for very many years has been the risk of battery effects, due to e.g. dissimilar metals in floodwater, which in theory can create wrong side failure of d.c. track circuits by adding a small amount of additional energy into the system.
    Now, I've only very very quickly skimmed this paper over lunch (for obvious reasons I will be reading it in detail later), however my immediate thought - which may change - is that I can't see myself and my colleagues in the industry losing much sleep over this. One issue is whether this source will actually couple enough energy in to drive the detector relay - we're not talking about electronic detection as with modern track circuits, this actually has to drive what I can only describe as a hoofing great relay (although to be fair we are only talking about additional energy on top of the correct track circuit drive, so this may be credible). Far more significantly, even if this source does persist for long enough to energise the relay (they're not quick), for this situation to result in an accident it then further needs to persist long enough to allow the green signal to be illuminated, for the driver to see it, pass it, and hit the train in front. Now, in track circuit development we do consider ANY energisation of the drive relay when the train is on the track as a wrong side failure, but there is a significant time level before there is an actual railway level hazard. As far as I can see this paper only talks about voltages, rather than duration, and both are critical - but again that may be my error in reading it quickly.
    To be honest what I would be (and we are) concerned about is the right side ("safe") impact. Not on d.c. track circuits, which are basically only a power supply, a resistor, and a relay and so as tough as old boots, but on modern electronic track circuits - and axle counters, and balises. These are designed to fail safe if "space weather" or any other EMC effect occurs, but "safe" means setting the signals to red - and then manually getting the train and passengers back to a place of safety. And that manual process is where accidents actually occur. So resilience to space weather absolutely is an issue, I'll let you know later what my further thoughts on the safety issues are.
    But many thanks Roger for bringing this up, and for adding the link to the paper itself, I wasn't aware of this.
    Thanks,
    Andy
  • P.S. I HATE the sub-heading on the E&T article "Space weather could have unintended and dangerous effects on the UK’s train networks, including switching signalling from red to green, according to new research." "Unintended" yes, "dangerous" is, at best, an "unhelpful" term. I'm sure they'd argue that they've only said "could"...which would be fine(ish) if it was in the tabloid press.
    Now, leaves on the line, they genuinely do result in dangerous failures of track circuit systems, including switching signalling from red to green. If E&T want to worry their readers they could try worrying them about that...but of course that's not "news" though, it's been true for 150 years!
    Rant over,
    Andy
  • Ok, having read through it properly now: It's a good interesting paper. The authors are clear that what they've built is a coupling model, not an analysis of the risk to the railway. And equally they are clear that they have not analysed the time factor, and that this would need to be considered to determine the actual level of risk.
    I think it's unfortunate that in their paper they have (I am sure inadvertently) suggested that a relay being energised leads to an unsafe condition. They've described the response time of the relay "on the millisecond scale" (it's specified in BR939A as 20ms), but that's not the issue, it's whether the fields persist long enough for that relay to stay energised such that the driver sees a green signal. It's not an edge triggered system, it's a state managed system - as soon as the relay drops back the signals will turn red / amber as appropriate. The paper isn't wrong (and the rail advisors they've quoted are good and very much know what they're doing!) but imo would have benefitted from a bit of clarity there.
    So what I feel the paper completely misses is any background on how long such fields exist for in a steady state, without that it's impossible to judge with scale of a problem this is. To be fair, that's not what the authors were trying to present, all they are actually presenting is a coupling model which others can use to carry out the time varying analysis. But since presumably such data exists in the sources which the authors quote as background on the field strength (or at least in sources which are in turn related to those sources) it would have been useful to present those.
    And, lest it scare anyone from travelling on the railway, d.c. track circuits have been in use in the UK for - ok I'm not actually sure (I should know!) and Google's letting me down, let's say 120 years? That's not saying this isn't a problem, it may indeed turn out to be a source of some of the odd blips we see - the pain with track circuits is you get unrepeatable blips which are impossible to pin down and could be from many causes.
    So 9.99 out of 10 for this paper. But, sorry, 2 out of 10 for the E&T article. The quotes in it are literally correct, but the context is alarmist and unhelpful. All the paper has presented (and I think all it's authors intended to present) is a coupling model, with an argument to say that that model may be useful to consider a potential safety issue. That's a very long way from saying that there actually is a safety issue.
    But next time we're investigating reports of d.c. track circuit blips - right side or wrong side - it's another potential cause we can throw into the pot, so to be fair to E&T they have finally published an article which might come in useful to me in the day job! Smiley I will admit I hadn't come across this issue before, and probably should have done. Which just goes to show there's always new things to learn.
    Meanwhile, when you're frustrated by train delays due to leaves on the line, be grateful that that cause of wrong side track circuit failures is being taken seriously (it doesn't do much for train braking either).
    And tbh more worrying is the suggestion in this paper that the West Coast Main line really does have d.c. track circuits (and therefore block joints). Surely it's all axle counters or jointless track circuits now? Nearly 20 years' ago we were tendering to move it to ERTMS!
    Thanks,
    Andy
  • P.S. Having googled "track circuits space weather" E&T was not the worst, so far my prize for that goes to the headline "Solar storms could cause train accidents, scientists warn". Oh no, maybe it's been beaten by "Weather from outer space 'could make trains crash into each other' "
    It's not a good idea to read headlines on a subject you know something about...
  • If it is useful the time scales of the high ampoitude events that are being worried about are minutes to hours, with the fast changing parts being sub (20 mins) cycle period, but very variable. (that would be shocks and aftershocks to the magnetosphere from the arrival of a burst of particles following a coronal mass ejection in our direction.)
    From this report. looking at the Spanish grid.
    There are however other faster mechanisms, usually lower amplitude and also there is evidence that the near-equatorial events contain more high frequency components
    From this paper
    Equally there are slower patterns that are essentially related to the earths rotation  period, i.e. 24 hours - if you wait long enough, you will see it....
    A longer read, with some explanations of the mechanisms, in this thesis.
  • Thank you Andy,
    The E&T headline and article triggered my BS detector. The actual paper seemed reasonable but I don't have the background knowledge to judge it properly.
    The headlines very often don't match the actual science/engineering.
  • Thanks Mike, the interesting question for this issue is how those disturbances periods relate to d.c. shifts, it looks as if the underlying data may all be available (e.g. in that very useful thesis you've linked to), but it may need to be modelled differently to determine the expected periods of net d.c. voltage, and then an overall model built, incorporating the model described in the Lancaster paper, to determine the actual risk.
    I won't comment here on how this may or should happen as I'm not going to risk treading on toes. But generically it's that interesting conundrum: to determine if there is actually a credible risk requires funding, but how do you justify allocating funding when you don't know if there is a credible risk!
    Cheers,
    Andy
  • Ah - I suspect the sensational if off the track headlines are the mechanism to drive the availability of funds, first  for a 50 page 2 week case-study by some well known consultancy or other, probably at about a grand a page, for the civil service to digest,  and then when this concludes, as it must of course, as all you can do in 2 weeks is a literature survey, that further experimental work is needed as the risks are as yet unknown and hard to model, then the university gets what it always wanted, research funding for another student for a 3 year PhD.....
    Or I may be a slightly too cynical so-and-so...
  • I wouldn't have dared write that (particularly in this case), but...yeeeeah.
    (Incidentally my time for Track Circuit EMC consultancy, at least to RSSB, is given by my employer pro bono, which is actually a bit odd.)
    That said, no-one, not even a university, is going to make a fortune from rail industry research! I guess for this issue I best fit into the "civil service" part of your description, and we simply don't have access to funding to fund projects that last more than three months at a time. Which in turn brings its own problems.
    Generally issues like this would actually have to be funded by suppliers, on the principle that it's the supplier's problem to prove that their system is safe, unfortunately in this case there is no supplier (at least none with the technical knowledge to look at this) as d.c. track circuits are basically obsolete - one of my jobs when I worked for one the major suppliers was to make our version of them obsolete!
