How safe are the Boeing 737 Max 9 aircraft?
I'm sure some have seen the news over the weekend about the latest issue with the Boeing 737 Max series
As a frequent flyer in Boeing 737's I've taken an interest in this story as to be honest it's confirmed by thinking behind why I ALWAYS have my seatbelt fastened throughout the whole flight (unless getting up to use the facilities that is)
From the news reports I've read it seems that an emergency door blew out from the rear section of the plane. The Max 9's are similar to the Max 8's I believe in that there is an additional emergency exit between the over wings exits and the tail end of the plane and it's one of those doors that was the problem.
Why would that be though? That's not a door that's use for entry into the aircraft unlike the front and rear doors so would have been fully secured surely? Could it be faulty design or materials failure? Or human error during construction maybe?
  • I wonder what kind of nut and bolt arrangement is used for the Plug?
    Does it use
    - Locktite (other brands are available)
    - Second nut up tight against the first nut
    - Split pin throught the nut and bolt arrangement
    - Sping washer under nut
    - Serrated washers either side of workpeice
    - Lock nut with Nylon insert
    People need to understand that vibration on a plane can do strange things to fixings as can the changes in pressure
  • Because you can sell a whole row of seats aligned with a plug bot you can't put seats aligned with a door.
    So the basic answer is it makes more profit for the airline.
    Companies exist to maximise their profits and cut every corner they can get away with to achieve that.
    Note 'get away with' is subject to laws, regulations, customer pressure, and in some cases ethics/morality
  • In the Max 8's there are seats next to the additional door (only two for passengers) and a jump seat for a crew member right next to the door. I had the 'pleasure' of sitting in that row recently with the crew member literally right in my face JoyFlushed
  • The slightly sad and worrying  thing here is that loose screws are not some high tech hard to grasp failure mode, and in a car or any other product would just trigger a recall notice.
    In a newish car yes, but not in an older one - having had the brakes fail in my wife's car over Christmas, due to a calliper basically dropping off the car, something I'm very aware of! Whereas this incident, like all aviation incidents, will be picked over in huge detail for root causes, irrespective of the age of the vehicle. Hence I'm rather more nervous of crossing the road in front of 16 year old cars of a certain make and model than I am of flying in a 737...
    (I'm not going to say what make and model as that would be unfair - could have happened in any car of that age.)
  • Loose screws are necessary if the airhostess is to be able to unscrew the emergency door quickly.  The H&S regulations need reviewing to be practical and safe for both crew and passengers.
