How safe are the Boeing 737 Max 9 aircraft?
I'm sure some have seen the news over the weekend about the latest issue with the Boeing 737 Max series
As a frequent flyer in Boeing 737's I've taken an interest in this story as to be honest it's confirmed by thinking behind why I ALWAYS have my seatbelt fastened throughout the whole flight (unless getting up to use the facilities that is)
From the news reports I've read it seems that an emergency door blew out from the rear section of the plane. The Max 9's are similar to the Max 8's I believe in that there is an additional emergency exit between the over wings exits and the tail end of the plane and it's one of those doors that was the problem.
Why would that be though? That's not a door that's use for entry into the aircraft unlike the front and rear doors so would have been fully secured surely? Could it be faulty design or materials failure? Or human error during construction maybe?
  • Hi Lisa
    URL below might be a starting place
    https://www.faa.gov/newsroom/faa-statement-temporary-grounding-certain-boeing-737-max-9-aircraft
    The CAA will shortly have something similar in place hopefully
  • As I understand it, there are two versions of the "9", the one for one for budget airlines has more seats so needs an additional emergency exit.  The other airlines have fewer seats, so that the extra exit is replaced by a door shaped "plug" which has a window.  This is supposed to be permanently fixed in place and from the inside looks like an ordinary window.
    The incident was lucky in two respects.  The seat by the window was unoccupied, and the blowout happened when it did.  Three or four minutes later the altitude would have been much higher so the outside pressure would have been much less and passengers may have had their seat belts unfastened.
  • Interfering with the planes structure just to satisfy some H&S emergency evacuation risk assessment.
    is not a good idea if that is what happened.
  • You would hope that as every passenger  plane has to be able to fly safely  with any one door open, it can also fly with the plug out as well - so the actual structure of the plane does not depend in any way on either being present.
    I suspect we we will eventually be told that the plug retaining bolts were the wrong ones or were not bolted in properly, as I'm sure the actual design would have been very thoroughly analyzed in both door and plug configurations, when correctly fitted, but presumably not as actually assembled  correctly- hence the checks.
  • We are talking about the Boeing 737 Max here - a plane that was designed wrong from the start.  I wouldn't like to guess whether it was a rushed design without proper tests, or something built in a hurry to clear the backlog of outstanding orders.
  • Hmm. well this just now from Reuters...
    Does rather look like someone at the factory forgot something -perhaps the  threadlock or a torque wrench.
    Not exactly a confidence inspiring newsflash.
    https://www.reuters.com/business/aerospace-defense/no-data-captured-alaska-airlines-737-cockpit-voice-recorder-ntsb-chair-2024-01-08/
    "Jan 8 (Reuters) - United Airlines (UAL.O) has found loose bolts on multiple 737 MAX 9 aircraft, it said on Monday, referring to the Boeing model grounded after a cabin panel blew off an Alaska Airlines-operated (ALK.N) plane in mid-flight Friday.
    United found issues related to the installation on several panels that were being inspected following the accident, it said in a statement."
    Makes one wonder what else has been cocked up that has not yet come to light.
  • Why would you replace a door with a "plug" though? If there is a door there then why not just leave it there as an additional emergency exit if there should ever be the need to use it?
  • doors do have to be checked and maintained and that takes time and costs, Also one that is blocked by  a seat is not a useful thing - it may even  cause folk to run towards it in situation where they should be going the other way to a real exit. Far better if it does not look like a door at all and  mislead.
    Equally also far better then if it is actually attached to the plane as well of course....
      if not you may as well be held on the outside of the plane with sellotape.. but lets not give the budget airlines ideas.
  • I would also lob in that the incidents and accidents that make the news are not the ones to worry about...because they're the rare ones which make them newsworthy. The most dangerous part of air travel is still, by a VERY long way, driving to the airport or - for those who like living really dangerously - walking to the airport! And part of the reason is that aviation incidents like this are extremely thoroughly investigated to root cause level, whereas a door falling off a car would just be another door falling off a car...
    There's an interesting thing here about public perception, something about very obviously putting your life in someone else's hands (particularly at high altitude), I'm not sure whether it's that we completely misjudge the actual risk in those circumstances, or whether it is that in those circumstances we have a much lower tolerance of what is an acceptable risk. Probably a mixture of the two?
  • true, but the consequence  from that failure is also lower. If my car door starts to falls off on the M3 there is a good chance that I can get to the side and no harm will be done. Even if it does detach at full legal speed (!), it is likely to affect the car behind more than it affects me, assuming  I do not crash in surprise, and then only 1 or 2 people will be involved.
    Mind you a colleague of mine was once greeted by a domestic bath tub in the middle of the motorway, then thing having dropped off the lorry in front.   Luckily he was obeying the 2 second rule and swerved and missed it.
    Very few planes crash, but when they do it is spectacular. But  i agree to look at car accidents, even just the fatalities  in the same detail would be impractical.  We go further between accidents in planes, but we make far more trips in cars and sometimes make odd and perhaps rash judgements about speed or route when we have a personally interest in getting to some event or other on time,
    The slightly sad and worrying  thing here is that loose screws are not some high tech hard to grasp failure mode, and in a car or any other product would just trigger a recall notice.
