Solar Energy Systems installation UK - lack of skills
As I researched Solar Energy systems for over a year now I discovered how little I understood the dangerous realities of Solar installations even though powered at ELV level <50Vdc.  The difference being that you are dealing with a constant current of 50 - 100's A dc.  Average Joe, maybe used to Auto/Truck 12/24Vdc  systems probably sees the system as safe - you dont get a shock (boat owners will disagree).  So the hazards of installing a dc distribution system  within a domestic house and the potential to cause disastrous fires are totally underestimated.  Even the average tradesman electrician will not have sufficient training in such matters in his CPD scheme.
To make matters worse, as a result of a question by a neighbour who want to suggest to his lad that he follow an Electrician apprenticeship, I discovered that my area (SE UK) has no regular Technical College Route pursuing CnG courses.  Apprenticeships are very rare and as a rule focus on training junior managers.
In short, a young person cannot readily find his way in to becoming and electrical tradesman ( I have to make a distinction between the concept of a Technician here)
When you aggregate the complete installation identifying all physical components, the SLD suddenly becomes quite complex.  ie Going from Panel Arrays > optomisers > cables > marshalling boxes > Fuse links > Isolators > Master Circuit Breaker > Inverter (s) > Battery Bank > Domestic Consumer Unit > Grid resale meter > Master Isolator > standby generator > Auto Transfer Switch, Control and monitoring systems, Emergency shutdown scheme.
When you seen the numerous wannabee hopefuls going offgrid and often their lack of formal technical training they dont realise how dangerous their rough and ready installation is
I can post links to many sources of my concern here if there is sufficient interest
Robin
  • BUT  the sad thing here which my OP highlighted is that we dont have any formal training worth a damn to promote theis level of Safety Training
    Agreed ... not everyone has the relevant training and experience.
  • Yes, arc flash energy at 12 V may well be low,
    and of course the arc flash is therefore not sustained for long enough for it to be what we know of as a "full blown flas" ... This particular point raises something very  interesting and important, in that if the voltage is sufficiently low, the model of "fault of negligible impedance" isn't always applicable ... the results are either:
    • More risk of arcing at the "higher end of ELV" in DC systems - possibly risk of arc flash if there's sufficient current (although "sufficient" here may well be surprisingly low).
    • More risk of a high resistance fault  at the "lower end of ELV" (say 30 V AC or DC, or less ... only a finger in the air) leading to fire - importantly, this is a possibility  with AC or DC. Having resistance in the fault may cause overcurrent protective devices to fail to operate.
  • That's more than sufficient current to draw an arc
    Indeed, but nothing a d.c. circuit breaker towards the inverter end would do anything to help. I don't think we have DC AFDDs available yet (and no obvious place to position one in a PV string either). I guess it's back to the very old school methods - insulation, sheathing, maybe put +ve and -ve in separate conduits etc and keep some physical space between them(*) to manage the risks of parallel arcs.
    * but not too far apart, we don't want a big loop, for EMI reasons.
  • Your reply and vid are out of context with my assertion  ie you are referring to a carbon arc system.  My topic concerns fault currents in wiring/ protective devices etc using metal interfaces.  I am frustrated at deliberate attempts to dilute the issue of dc power system safety.  There is so much absurdly naive rubbish promoted on YT and giving untutored  Joe Public the idea of playing around with setting up his own solar system inside his house.
    There are numerous vids with ca 100,000 followers showing how to meddle with Lion 18650 cells and rather trivialising the safety issue.
    https://www.youtube.com/watch?v=CYBnEGYWgz4
    How many  people just throw lion cylindrical cells in a drawer together (just like you might with spare zinc carbon cells)
    Have you seen vids of refuse lorries discharging their loads in the street because a lithium battery started a fire and produced smoke.
    This is a regular occurrence in recycling centers
    Would you let your kids experiment with lithium batteries?
    When I am developing a project using Lions on my bench, I have the following kit to hand
    A large steel cooking pot with lid containing a couple inches of sand at my feet
    Wire/cable cutters to hand
    Leather gloves and large tongs
    Wear goggles over 12Vdc
    Keep a plan water mister to hand to quench arc flash
    Keep room exit clear in case of catastrophic event (room rapidly fills with highly toxic HF smoke)
    How many of you understand the need for these precautions indoors?
  • A simple rotary isolator between PV panels and inverter is a pretty well accepted way of doing things. It's only intended as an off-load isolator to allow work on the inverter.
    A lot of people dont understand the difference between an isolator switch and a circuit breaker.  Joe Public equates it with the light switch on a wall.
    I didn't specify that, and nor did you.
    Once carbonisation takes place on the surface of other conductors, though, more prolong "sparking" and quasi-arcs can occur, but still perhaps not "arc flash" - I wouldn't, however, like to say it was never possible under any circumstances with 12 V DC systems.
    I fully support you in this, and the other things you have said ... except perhaps I would recommend wearing eye protection even at 12 V DC.
    In real installations, I have seen welded and vaporized components resulting from short-circuit faults in 12 V DC and 24 V DC systems (without carbon rods Sweat smile) and for that reason, I would make the recommendation for at least some eye protection, especially where the prospective fault current is going to be more than a (very) few amperes..
  • In the UK where we do not have such dry desert grass I show the Scouts electric fire starting with a brillo pad and char-cloth to get the kindling going. This also means you do not need anything like as much current, a few alkaline D cells will ignite the fine iron wire at a push. As a fire starter, it is only ever a novelty, and the flint and steel or matches are much preferred if you are in a hurry, but it still makes a bit of an 'ooh' demo to those who have not seen it before. I try to make a point of mentioning about not putting bare terminal batteries loose in your pocket at the same time.
    I also point out that a standard Mars bar, (220 calories. = 924kJ), a 180gram small stick of dynamite (~ 1MJ) compare, and a lantern battery made of 4 D cells (each celll 25 Watt- hours = 3600*25=90kJ ) is about 1/3 of that, but the example is to show the error of thinking that way - the key is how fast you get the energy out, in the case of the bar, over hours by digestion, the battery over tens of seconds to minutes and the dynamite in tens of microseconds.
  • Mike the Magician at a kids party.  What we have here on this OP is big kids encouraged by the Wicked Witch (social media, ill informed ego-trippers on YT, malicious misinformation etc) encouraging bigger kids to play with fireworks (lion batteries, dc heavy current installations etc) and become a tribe of opinionated "techies" who doesnt do sums and believes that "suck it and see" is the way to go.
    Who cares about 'Ome's Law  Watts the fuss about?  Look at the huge tribe of Big Kid Arduino dabblers who fool themselves into thinking  they are smart when they make leds twinkle.  Put them in the real world for employment and you find them unemployable because they werent infused with a sense of  discipline from  formal technical  training when they were young and are too old to change their self taught  mindset..
    FWIW I have to chuckle to myself cos I sound like an advocate for National Service.
    So back to my bench I have testing to do.
    OBTW
    Notice some things about these YT vids
    a) They feature a splash of the Presenter - "in your face"
    b) They are ca 25 - 35mins long
    c)  Their content could be said in <5mins
    d) They a filled with crafted teasing so you have to watch right thru
    e) Their  length allows for 3+ sponsor ad slots
    f)  They are optimised to beg for "Subscribe " clicks (which generates Sponsors' $$$ income"
    g  At the end you have wasted a morning on a half dozen of these and conclude its 99% rubbish.
    It turns you into a "Grumpy Old Man"
  • I take the Scout leading quite seriously actually and devote much of what would otherwise be my free time to it - I see modern society as becoming very brittle and people unable to handle it if any one thing in the ever longer chain fails, and making sure youngsters know how to use matches safely, how to cook a decent breakfast lunch and dinner from scratch, the basics of first aid, how to read a map and so on I see as generally useful skills to pass on. I am aware that some see the Scouts as a baby sitting service, and some groups may be run like that, my troop is not.
    I agree with you on the infuriating youtube videos and tend to ignore them. I prefer the ones that are just real people, and there are some very good ones, especially for mechanical engineering and bushcraft - but a great many that are just cash cow dross as you indicate.  Electrically I prefer things like the likes of John Ward for electrical, and BigClive's videos for the lets look inside a whatever it is - as neither are like that.
  • Indeed Big Clive is a tonic https://www.youtube.com/@bigclivedotcom . (1Million fans) A leccie specialising in fairgrounds and local Authority street lighting carnival lights events etc.  10 years if de-constructing electrical Cheap Charlie gadgets and some tongue in cheeky stuff and many quite dangerous and should be banned.
    A notable exposure is the flagrant abuse by CC of the EU CE self certifying system (fake CE stamp meaning China Export)  ggle it.
    FWIW here are some other sites I consider offer valuable enlightenment (no affiliationBTW)
    https://www.youtube.com/@JulianIlett
    J does teardowns particulary of LiB SiB techonology, solar system etc from of more technical angle 200k fans
    https://www.cruisersforum.com/ an unlikely  source for electrical dc systems afloat - decades of experience, also links to ABYC and its mandatory electrical regs for boats and formal inspections (no sign off , no insurance, no mooring!!!!!!!)
    https://www.youtube.com/@OffGridGarageAustralia/search (80k) Andy in OZ going 7+ years  former IT Tech who specilises in Lithium power banks systems BMS etc.  Salutary to note his casual approach to electrical installation design - tbh  regs have tightened up considerably over the years and Solar installation need a qualified State employed Inspector to sign off on installation or you dont get a permit to operate   100's of vids with genuine trials and testing but newer vids, he has become rather too sponsor supported (which he does disclose) but Im sure he uses any $$$$ he gains to support the costs of his extremely time consuming work - he is a legend.
    https://www.youtube.com/@HBPowerwall/videos 600k fans Pete has being banging on repurposing old laptop batteries he got for free starting 10 years ago.  A self confessed technical numpty who doesnt do sums  but he started out 10 years ago collecting free laptop battery packs and fumbled his way through the years making all manner of untutored illiterate techie mistakes and to his credit he owned up to them as he found work-arounds with help from his fans' comments.  Although his naive approach was obvious he had quite a few disasters and near misses.  His 600+ short humble vids were honest , untainted by sponsorship and amazing time consuming persistence.  He is a true legend and gave up battery building 3 years ago as technology had moved on so much and old battery packs were no longer available.
    You have to beware of Solar Forums as some of them are heavily moderated by sponsorship (not always disclosed) - for example trying to discuss the proprietary control over swtichgear and fuses - for dc work - such a lot of ignorance here)
    Anyway - hope it adds to our Knowledge Base
    Robin
