Wind versus Coal
An interesting little side piece in E+T.  It will require 233  5 MW wind turbines to replace one 500 MW coal fired power station. This will occupy 55 square mile. This is also assuming quite a high capacity factor of nearly 43% but I will keep to the quoted numbers.
I am not sure if it is viable /sensible to build new coal fired power stations. The Chinese and the Indians certainly think that it is. So to look at the nuclear option:
To replace a 3 MW nuclear power plant with 2 EPR units, Hinkley point C or Sizewell C, will require 330 square miles to be filled with wind turbines (maybe more depending on the wake effect).
www.wind-energy-the-facts.org/wake-effect.html
This is more than twice the area of the Isle of Wight, not impossible but politically very difficult.
The more important question is the resources required. It is difficult to find numbers for the concrete and steel requirements for wind turbines. I do understand that this is affected by the ground conditions and foundation requirements however some number exist in this 2011 document.
pubs.usgs.gov/.../sir2011-5036.pdf
Table 5, page 12,  gives 100 tonnes of steel per MW and 400 tonnes of concrete per MW.  So to replace Hinkley Point C will, according to Kurt Cobb, require 6990 MW of wind turbines.
Steel 6990 * 100 tonnes  = 699 000 tonnes
Concrete 6990 * 400 tonnes = 2 796 000 tonnes.
The quoted figures for Hinkley Point C are:
Steel 280 000 tonnes
Concrete 3 000 000 tonnes.
https://www.newcivilengineer.com/innovative-thinking/projects-innovation-drives-hinkley-point-c-16-01-2019/
https://chamberuk.com/chrisfayers/
So similar amounts of concrete and a lot less steel for Hinkley Point C. The NPP has an expected life span of 80 years, wind seems to be typically 20-25 years.
Hinkley Point C could also use a lot less materials, cost less and be on time if it was built somewhere other than the UK:
www.spectator.co.uk/.../
Is wind power a sensible use of our finite resources?
  • Tides vary with springs and neeps.
    How you generate enough tidal energy to power an industrial civilisation is for the birds.
    As for weather being predictable is ridiculous beyond 24 hours.
    The only prediction is the rich turbine owners will be getting richer off the back of the highest energy costs in the world in the uk
  • Hello Jon:
    Now you have mentioned the other parameter TIME but you failed to mention prediction accuracy! As time is increased the predication accuracy decreases.
    Peter Brooks
  • Tidal power generation is very variable swinging from zero to full output twice a day (approximately). To be classed as despatchable a significant back up or storage system is required.
    I would prefer my life support system to be nuclear or fossil fuel powered rather than from renewables.
  • Well with reversable generators (generate on both ebb and flow) it is 4 times a day and at different times around the coast, and the slack tide periods are relatively short.
    But I agree, nuclear is best for standby.
  • Hello Roger:
    Now you have added another topic to this thread by your reference to "my life support system".
    From a personal perspective using electrical "mains" power for a persons "life support system" is not acceptable.
    During storms and disasters the "mains' electrical power can disappear for hours, days and weeks.
    If I had a LVAD (heart pump) installed in my body I would have to put in a external backup electrical generator that uses LP gas or regular gasoline.
    Peter Brooks,
    Palm Bay Florida
  • To go slightly aside again on this topic. Could tidal generation be run synchronously? Normal hydroelectric power can but could a direct synchronous generator operate with what is a continuously varying (sinusoidal) flow regime and offer grid stability?
    Inverter coupled systems like wind and solar do nothing to help the grid stability and battery storage systems even with ‘advanced grid forming’ inverters don’t seem to be enough.
    This article notes the blackout problems at Australia’s Broken Hill when the powerline coupling to the Australian grid was broken in a storm. Even though there was apparently ample wind, solar and battery power available the micro grid would not run without connection to a real grid.
    https://judithcurry.com/2024/12/05/wind-and-solar-cant-support-the-grid/
    This may have been a technology or management problem, there is another view here:
    https://reneweconomy.com.au/energy-regulator-joins-probe-into-reasons-for-lengthy-blackouts-in-storm-hit-broken-hill/
    Or maybe it was the wrong sort of battery:
    https://www.agl.com.au/about-agl/operations/broken-hill-battery-energy-storage-system?zcf97o=vlx3ap
  • Roger:-
    Regarding power systems in Australia- I don't know very much except 1) Tesla Storage Battery systems have been installed in Western Australia and 2) There are big plans to connect a Northern Australia's solar farm(s) to Singapore, using underseas cables made in a new cable manufacturing facility in Tasmania.
    As a result of climate change many older Hydro systems are running out of water here in the US,
    Peter Brooks
    Palm Bay Florida
  • Interesting read - while it looks like there were a few technical challenges that really should have been sorted better, it reads as if management/maintenance failings alone were quite enough to cause the disaster:
    one of the diesel generators that were supposed to provide back-up power was out of action, and the other was incapable of meeting community and business demand.
    the Broken Hill battery had been deliberately disabled from providing this “islanding” service, under orders from transmission company Transgrid which had chosen instead to deliver those services through a new advanced compressed air storage project.  ... But that facility has not even begun construction, and won’t be built until 2027.
    with a nice summary from the author:
    But, like many of the challenges facing the green energy transition, this is not really about the technology, but whether the regulatory processes, the rules and grid management protocols are fit for purpose.
  • More likely population explosion than climate change has emptied your reservoirs.
  • More like lack of snow over the last few years. This years US winter is projected to be colder with more snow in the western mountains.
