Installing a Renewable Energy Electrical Bypass Switch
If a customer request the installation of an electrical Bypass switch system for an existing battery system.
As this is a commercial property with existing Battery system that requires often shutdown of the site to maintain the battery system. The Customer has asked a electrical contractor to design and install the Full bypass meaning the battery can be isolated from the main supply and load for maintenance .
my question is what test and inspection documentation should the customer expect as confirmation the design and installation is in line with electrical regulations on completion.
  • what test and inspection documentation should the customer expect as confirmation the design and installation is in line with electrical regulations on completion.
    A normal BS 7671 Electrical Installation Certificate would have been a good start I would have thought - with the usual signatures for design, construction and inspection & test.
  • Agree, but add some sort of functional load test, as presumably if there is a great glitch when changing to back-up then its not that useful.
    Are you the designer or is that the customer - it makes a difference as to who is responsible if things are not as expected during commissioning.
    Enough design information needs to be supplied - if need be instructions and diagrams, that the system can be maintained and used safely.
