Thermolysis of heat-insulating intumescent coating
Could some one give a coherent conceptual mechanism that could be a scientific and technological foundation for formulating fire-retardant intumescent coating that could unambiguously describe physicochemical nature of the process of   thermolytic synthesis of the charred heat-insulating layers of intumescent coating on substrate/steel/polymer?
  • Probably.
    However,  they would need to understand the question first !  So - what exactly do you want to know ?
  • I need to know the mechanism that describes the physicochemical nature of the process of thermolytic synthesis of intumescent coating on steel substrate or polymer substrate.
  • The mechanism that describes it will be words and diagrams.
    The mechanism of producing the coating itself is probably not going to be thermolytic synthesis at all, for any current intumescent at least,  the common ones are all 3 of the normal methods for making paint, namely oil based, water based and epoxy based. Which one you reach for depends on the substrate and the environment it will be used in .
    I ask again what exactly do you want to know ?
    i.e.
    What are you trying to achieve?
    What is the problem to which you seek a solution?
  • Thank you Mike for a brief explanation
    I would like to understand the mechanism of formulating inorganic heat-insulating coating that could be applied on polymer/steel substrate and the characteristics of charred heat-insulating layer on substrate due to diffusion and permeability of gases. I want to achieve the inoganic intumescent coating with high fire retardance.
  • you may find a read of a few patents on the topic helpful to get up to the state of the art.
    I'd start with this one https://patents.justia.com/patent/10131800 as the intro is a good state of the art summary
    Then  https://portal.unifiedpatents.com/patents/patent/US-4247435-A
    Then https://data.epo.org/publication-server/rest/v1.2/patents/EP2093263NWB1/document.html
    The most common approach is something that decomposes to  an acid, that then reacts with a carbonate or more recently a more complex organic,  as a blowing agent to create CO2 when hot, Then you need a second component, that in effect foams with the bubbles of CO2, and burns to  a char but does not disintegrate. This structure of frozen bubbles is a good insulator and protects the substrate it is formed upon.
  • Hello, dear Mike,
    I want to acknowledge for taking your time to comprehensively respond to my questions. i really appreciate your helpful explanation and the links you sent me as supplementary materials.
    Once again, thank you for your help
    Kind Regards,
    Ponsian M.Robert
