Hi
I am looking to find an expert on static electricity to help with a challenging issue I have on a process line.
Gary
Hi
Gary
Hi Gary
Can you provide a little more detail so that others can chip in to help?
Lisa
We have a process that produces deposition products (think small pieces of spaghetti) that is attracting a charge and causing issues with the process equipment. Because the process is registered then changing the process including product contacting materials of construction etc is not easy.
So what is happening in the process and what measures are already in place ?
Thinking of humidity controls, atmospheric ion generations, weakly conductive surfaces and so forth. If it really is spaghetti, then moisture content will be very significant.
Just to be clear...the product is not spaghetti and that is just to help describe what the product is like physically. My understanding is that this equipment is in humidity controlled area and that increasing RH has been explored. There are atmospheric ion generators being used and there are some dissipative surfaces for some parts of the process. I do not think any measurements have been taken of the static charge on the product itself.
The charge on the 'not spaghetti' itself is probably quite hard to measure accurately, and in any case is a symptom, not cause, and just recording that on its own may not be that useful.
Is the stage in the processing that is causing the initial charge separation clearly identified yet ? - Often measurements of potential can allow this to be narrowed down mostly coming from one particular belt or roller or point where parts are peeled apart or something like that? That does not mean that production step can be eliminated of course, but it does mean that the neutralization effort can be concentrated to the one area.
I remember a situation once where high Nylon content carpet was the cause for static built up
presumably scuffing against footwear with insulating soles or trolleys with insulating wheels ? Certainly dissipative (a few gigohms per square )floor coverings are very good start . Then you can fit drag chains or brush contacts to mobile equipment so it remains in contact with the floor while being pushed about, workers can wear heel straps etc.
Hi Gary
I recall that Southampton University was very active in electrostatics and see that Wolfson Electrostatics was spun-off in the 70's under Graham Hearn
