GBAD Network Safety?
"What are the best practices for ensuring the safety and resilience of Ground-Based Air Defence (GBAD) networks in the face of evolving cyber and physical threats?"
Context:
As GBAD systems increasingly rely on interconnected networks for communication, command, and control, the potential vulnerabilities to cyberattacks, electronic warfare, and physical disruptions are growing. I am particularly interested in:
  • Strategies for securing data transmission within GBAD networks.
  • Mitigating risks associated with integrating legacy systems with modern technologies.
  • Approaches to testing and validating the safety and security of these networks under operational conditions.
I would appreciate insights from those with experience in military systems engineering, network security, or related fields. Are there specific standards, frameworks, or case studies that you would recommend exploring?
  • I'd almost hope there weren't published standards for that kind of thing ... if the "other side" knows how you're protecting the system from any particular threat, it may make it a lot easier for them to develop a method of defeating it.
  • I would expect lots of standards, but would be worded as expectations, rather than specific "this'll do" levels. Have a look at the UK Def-Stans and US MIL-STDs. Plenty to go at.
    A lot of it is no (or minimally) different from all the other forms of computer, strategic asset and critical infrastructure safety and security, but applied with the appropriate focus.
    Known bugs will be patched, or procedures updated, or backups installed just as with all the other CVEs that plague use. Things that go 'bang' have plenty of attention. Wink
  • Air gap networks, and humans in the decision loop as well. Automated systems do not normally need a connection to the internet, and unless they do, they won't have one just for fun. Connections between sensors (imagine the RADAR bit) and the firing bit will be on dedicated line. Tempest specs will indicate how the larger threats like jamming of that link, are kept at bay.
  • There's also a lot of other specs that are just 'solid foundation' aspects to avoid some 'social engineering' aspects that could use procedural aspects to cause issues, such as power outage ride through. A lot of defence in depth, layered approaches, and Reason's Swiss cheese minimisation.
  • In the UK, at least, any documents that would be of any use to you will be classified.  Especially your second and third categories.
  • what do you me standards i can use, what can I use for hazard ID  for each of the hazard that need found for army combat operations, do we do user testing to find hazards?
  • do we do user testing to find hazards?
    Only when at war. More normally we prefer to do design verification tests and then user  acceptance testing by system demonstration..
  • If you've got access to Defence Standards, it might be worth having a look at DEFSTAN 21-088. This is what Ship's Combat Systems use. I think I remember meeting you at Abbey Wood so think you should be able to access this document (but look me up on MODNET and I can point you in the right direction)
