Saving money using batteries
Although I have solar panels in the garden, during this time of year there is a lot less sun and therefore the solar panels cannot always support the home or keep the battery charged up. So I charge the battery, from the grid, every morning when the price is low (~8.5p per kWh) for up to 5 hours so that we can use it to feed the house during the day. This has enabled me to reduce my overall electricity use during winter.
I have concluded that this type of approach may be of benefit to those people who are unable to install solar panels. Get a battery installed, with an inverter, and move to a tariff such as Octopus Go which allows you to charge the battery in the early morning at a cheap rate. This both allows you to save money and reduces the amount of electricity demanded from the grid during the day. For example, my home use depends on the inverter behaviour such that we use an average of 10kWh of electricity per month.
For example, last month it cost us £8.85 to keep the battery charged up in the morning. Then we used 13kWh which cost £17.87, which includes standing charge and VAT. So the overall electricity price was £26.72. The actual electricity usage was estaimated at 315kWh, which would have cost about £100.
We also use a myEnergi Eddi device to control our hot water. We also boost this in the morning when the price is low, then we boost the temperature during the later day from the battery when we need it. This helps us save gas, about 3,000kWh per year.
An alternative to installing a battery is to use an electric car if you have one. Electric cars and their home chargers are being developed so that they can be used to provide electrical power to the home. They can also be charged early in the morning using the cheap tariff. Car batteries are much larger than traditional home batteries so they could be used for powering modern devices, such as heat pumps. For example, my battery is 8.2kWh and my electric car battery is 60kWh.
  • I would perhaps style it more as cost saving rather than energy saving per se, or perhaps grid-friendly, but yes I think the principle is sound enough. Really you should include the capital costs into the equation (I think last time I did a back of an envelope reckoning, given the cost and lifetime of a LiFePO4 battery etc.a 1kWh battery round trip would cost about 10p - maybe that's improved a bit now?) - but still it works out quite nicely for many of the time based tariffs as the off-peak rates are often a lot less then 10p less than normal rates. Might be different if you had to pay someone to install the system for you commercially of course. Up-front costs will be relatively high so certainly not for everyone, but that's the case with most technology. The EV battery might be 'there already' but it won't always be plugged in when it's needed (presumably the car does move sometimes).
    There are other means to similar ends - I've recently installed a heat pump, which feeds a thermal store - so much of the time I can run the HP just on off-peak electricity .. which should work out cheaper than gas per kWh delivered.
  • It is a good thought process to use a battery to store energy when it is cheaper.  As long as the battery storage and inverter had a proper Risk Assesment before install.  Apparently someone done a FOI (Freedom Of Information) request and found that in the UK inverters are the primary cause of fire in Domestic Solar/Renable.  See URL below.
    https://youtu.be/TaMJ0EEIndk?si=AIttfKJiVLVtkDON
    Maybe the MCS (Microgeneration Certification Scheme) and IET and BSI along with the Fire Brigade need to discuss this further.  Is it possible that the product standard for UK inverters is to low?  Do they need to look to other counties like South Africa or Australia who are already in there 2nd / 3rd / 4th generation of renewable energy systems for their country product specifications.
  • We had our solar panels, battery and inverter supplied and installed by a MCS qualified installer confirmed by a certificate at the end of the installation. Our solar panels are in the garden and our battery and inverter in the garage. Our EV charger is also in the garage. You do need to think were to position them such that they are safe and secure and within reach of the internet router. Our battery and inverter is supplied by GivEnergy.
  • found that in the UK inverters are the primary cause of fire in Domestic Solar/Renable.
    Given that all the other parts of a PV installations (simple cables, isolators and PV panels) are rather unlikely to start a fire, doesn't naturally follow that the only remaining component does account for the few that do occur?
  • Given that all the other parts of a PV installations (simple cables, isolators and PV panels) are rather unlikely to start a fire, doesn't naturally follow that the only remaining component does account for the few that do occur?
    ...Assuming good design and workmanship and appropriate, quality products: Poorly implemented string connectors, damaged cables, loose connections and incorrectly specified or overloaded devices have historically been an issue with the industry, and product defects do sometimes occur.
