Lithium-ion battery fires: a new fire class
The ISO 3941:2026 standard introduces fire class L, dedicated to lithium-ion batteries. A major step forward given the growing risk these fires pose in professional environments.
Why a new class?
Li-ion fires behave unlike any other:
- Rapid thermal runaway
- Re-ignition possible hours after initial extinguishing
- Toxic gases and extreme temperatures (>1000°C)
- Extinguishing can be complex, sometimes requiring thousands of litres of water
Point right Conventional extinguishers are insufficient. A dedicated class was needed.
What does Class L cover?
Only lithium-ion battery fires (not metallic lithium).
X Does not cover solid (A), liquid (B), gas (C), metal (D), or cooking oil/grease (F) fires.
Extinguishing methods:
- Massive water cooling
- Prolonged immersion
- Li-ion specific agents (in development)
- Post-fire monitoring mandatory
Impact on workplaces: training & risk assessments
Class L changes the game:
- Fire training must be updated
- Emergency procedures revised
- Charging and storage areas secured
- Risk assessments (RA / DUERP) updated to include “Li-ion Fires – Class L”
Where is the risk?
Virtually everywhere:
- E-bikes and e-scooters
- Power tools
- Cleaning robots
- Smartphones, laptops, tablets
- Electric vehicles
- Energy storage cabinets
- Batteries and cells
Prevention and training are now essential. Class L isn’t just another regulation – it’s a paradigm shift in fire safety.
  • It's also a money-making opportunity for somebody.
  • There may indeed be commercial implications, as with any new safety standard. However, the emergence of Class L reflects a genuine operational gap: Li-ion battery fires behave fundamentally differently from traditional fire classes, and recent incidents show that existing approaches are not always adequate.
  • Humm, I wonder about other battery chemistries. The only time I've personally seen thermal runaway was with a sealed lead acid battery in a UPS. Fortunately the problem was spotted early and it ended up being moved outside and left for several days before it cooled down. I have my suspicions it might have all been a lot more dramatic if it had been left in situ, connected to the supply, in a closed box in the middle of a not that well ventilated computer room (it had air con for cooling, but that just recycled air, there was no exchange with the outside, so any released hydrogen or other gasses couldn't have escaped easily).
  • Very good point, Andy. Thermal runaway and hazardous gas release are not limited to Li-ion systems.
    Sealed lead-acid UPS batteries can also overheat under fault or overcharge conditions, with significant hydrogen evolution.
    In enclosed or poorly ventilated plant rooms, this creates an additional explosion and fire hazard, especially if ventilation is only recirculated cooling rather than fresh air exchange.
    This highlights that battery fire safety must always consider the full installation context: chemistry, charging regime, enclosure, ventilation, and gas management not just the cell type.
  • I think that BS 3941 2026 has been released a little premature so to speak.  Maybe there should be a Class M (other Class names are available for use)
    Class M for Mixed-Ion
    Li-ion battery in phones, tablets even vehicles are quite well documented and also how fast they can spread a fire or potentially be the cause of the fire.  But
    Class M for Mixed-Ion could contain other ION type chemistries like Sodium-Ion which are already being trialed in motor vehicles.
  • There are multiple types of Li-ion batteries.  For examples Lithium iron phosphate has a much much lower fire risk but insureres and other uneducated folk lump it in with the type in your escooter which are a very high fire risk.
    It doesn't help that when you speak it, Li-ion sounds like Li-iron
    Fire Risk by Battery Chemistry
    • Lithium Iron Phosphate (LiFePO₄): Lower fire risk due to a more stable chemical structure.  Thermal runaway typically starts at around 310°C, much higher than other types.  These batteries are less prone to fire under normal conditions and are preferred in safety-critical applications.
    • Nickel Manganese Cobalt (NMC): Higher energy density but higher fire risk.  Thermal runaway begins at approximately 150°C, and these batteries release more oxygen during failure, increasing fire intensity.
    • Lithium-ion (Li-ion) and Lithium-Polymer (LiPo): Common in consumer electronics and micromobility devices. Higher fire risk due to flammable organic electrolytes and high energy density.  LiPo batteries, often used in drones and RC models, are particularly vulnerable to damage and rapid thermal events.
  • Maybe need to call them Lithium Ferro Phosphate (maybe ferric if that's the technically correct one), just to get away from the iron-ion confabulation.
  • About “Class L” and ISO 3941:2026
    ISO 3941:2026 (3rd edition) does recognise lithium-ion battery fires as a distinct category (often referred to as Class L in discussions).
    This is a classification standard, not an extinguisher performance standard.
    It does NOT certify or approve any specific extinguisher.
    There is no globally harmonised test protocol yet (like EN 3 or UL 711) for “Class L extinguishers”.
