Importance of EMS in BESS installations and issues / challenges in its proper integration
Energy management system, in simple terms the control system for the BESS utility scale installations is the interface used by the operators for BESS management. It can be part of the BESS integrator scope but it is usually out of its scope so EPC integrates the EMS with the BESS controllers. This integration is important.
The discussion is open to professional to share their experience and problems faced in this aspect.
  • In my experience, the EMS is usually sourced from a third party rather than the PCS or BESS integrator, as its role is to aggregate data far beyond the battery itself. Because it acts as the master controller for the entire plant, we frequently encounter integration 'noise'—bugs and false alarms that unnecessarily interfere with operations.
    Common issues include, amongst others, false transformer temperature alarms, faulty fire sensor signals, or the EMS getting 'locked' in an SoC management loop between different battery racks or banks.
    The real challenge lies in the deep integration of these individually operated components: HVAC systems, temperature sensors, FFS, BMS, and the specific chemistry limits of the batteries. When you overlay these with TSO commands, grid operating modes, and over/undervoltage protections, any mismatch in logic leads to downtime. The EMS must not only communicate with these parts but also understand their physical operational limits to prevent these conflicting command loops.
