Preparing the UK Electricity Network for Rising Cooling Demand
The UK electricity network has traditionally been designed around winter peak demand, reflecting the country’s reliance on electric heating, lighting and seasonal energy consumption. However, recent summers have demonstrated that prolonged periods of high temperatures are becoming more frequent, bringing a new challenge that may require greater attention from engineers and policymakers.
Many UK homes were designed to retain heat during winter rather than prevent overheating during summer. As a result, there is growing interest in cooling technologies, including reversible heat pumps and air conditioning, to improve comfort and protect vulnerable occupants during heatwaves.
If the uptake of these technologies continues to increase, it raises an important question: are we adequately preparing the electricity network for a future in which summer electricity demand grows significantly?
Planning for this now could help avoid costly network reinforcement later. It also presents an opportunity to consider a more integrated approach that combines:
  • passive building design to reduce overheating;
  • energy-efficient cooling technologies;
  • rooftop solar PV to offset daytime cooling demand;
  • battery energy storage to reduce peak loading;
  • smart controls and demand-side flexibility; and
  • distribution network planning that considers both winter and emerging summer demand profiles.
The transition to Net Zero is changing how electricity is generated and consumed. Alongside the growth of electric vehicles and heat pumps, increasing cooling demand may become another important factor in future network design.
Addressing this early could improve network resilience, reduce future infrastructure costs, enhance energy efficiency, and help ensure that UK homes remain safe and comfortable as the climate changes.
Do you think future electricity network planning and building regulations should begin placing greater emphasis on summer cooling demand, or are current measures sufficient?
  • I'd definitely think that our first step should be towards preventing overheating in the fist place - there are plenty of means for shading south facing windows and so on and many features of "modern designs" for keeping heat in (insulation and controlled air flow) should be at an advantage when it comes to keeping heat out too. "Active cooling" should be the last resort - but I agree it will increase and the problem needs examining.
    The next question is how high would the demand for cooling be? At a first guess we might want to keep the house at maybe 10-15 degrees cooler than outside - compared with perhaps 25-30 degrees warmer in winter. Given that there are already plans to shift from gas to electric (mainly heat pump) heating, it might be that summer cooling demand would be less than winter heating demand as far as the grid was concerned.
    There are perhaps two sides to the national grid - generation and transmission/distribution. On the transmission side, things have to be built for maximum demand - so as long as the summer cooling isn't larger than the winter demand, no additional capacity should be needed. Generation though is another matter. We tend to have "heat waves" under unusually large and static high pressure systems - which means winds are low - so wind based generation capacity may well not be sufficient. Solar is the obvious counter-balance - but still some thought as to the overall balance between generating (and storage) technologies to cover situations throughout the year may be needed.
  • I agree that passive cooling should always be the priority. Improving shading, external blinds, reflective roofing materials, natural ventilation, and designing buildings to minimise solar heat gain can significantly reduce the need for mechanical cooling while also improving energy efficiency.
    Your comparison between winter heating and summer cooling demand is an interesting one. Although the average cooling load may be lower than winter heating demand, there is still a concern about the timing of that demand. If many households begin using air conditioning simultaneously during short heatwaves, distribution networks could experience high local peak loads, particularly in residential areas that were not originally designed for significant summer electrical demand.
    I also agree that generation presents a separate challenge. Heatwaves are often associated with low wind speeds, which can reduce wind generation output. Fortunately, peak cooling demand generally coincides with high solar irradiance, so photovoltaic generation could help offset some of the additional demand. The remaining challenge is ensuring there is sufficient energy storage, flexible demand management, and local network capacity to balance periods when renewable generation and demand are not well aligned.
    This is why I think the issue deserves attention now not because cooling demand has already become a major problem, but because planning for future network resilience is generally more cost-effective than reacting once widespread adoption has occurred.
  • If many households begin using air conditioning simultaneously during short heatwaves, distribution networks could experience high local peak loads, particularly in residential areas that were not originally designed for significant summer electrical demand.
    Would the same not be true of heating loads during a cold snap? (especially once heat pumps have generally replaced gas/oil boilers)
  • It will, and perhaps the question can be better framed, "how do we prepare the electrical grid to have the capacity to meet future demand and also replace the gas network?"
    The most enthusiastic proponents, expect the gas to be empty and decommissioned by 2050 or so!
    My money would be on slightly later, but even so that is likely to be well within the life of the supplies and wiring of all houses being built now and indeed plenty already built.
    At the moment most houses have a 20kW or higher power gas boiler for water and heating, though more care and control of heat losses may mean something smaller can be used if converted to electricity.
    Even so, just adding half that at extra 10kW per building would be a massive change to the load patterns.
    For sure cables are more stressed in summer, so the ability to ride-out what might be otherwise a small overload is better in winter.  More explicit use of temperature dependant ratings may be needed.
    If demand rises we may need to look at 3 phase in a domestic setting and  supplies within larger buildings such as blocks of flats may need conversion to  higher voltages beyond a certain point - it may become cost effective to use transformers rather than heavier cables.
    Years ago I was very impressed by how much power could be sent how far by 630V/1k3 three phase in a German factory, compared to what would have been UK practice of having a very beefy 230/400 cable - this sort of thing may need to be considered more here.
  • At the moment most houses have a 20kW or higher power gas boiler for water and heating, though more care and control of heat losses may mean something smaller can be used if converted to electricity.
    I don't think gas boiler power ratings will be a good guide to electrical demand, firstly because the highest boiler powers are for instant hot water heating Combi boilers, whereas electric hot water heating either uses lower powered elements combined with storage, (i.e. 3 kw immersion in a cylinder), or heat-pumps with a cylinder (2 kW input?) or short-duration appliances like a shower (max 10kW) but which have high diversity across a neighbourhood.
    For the space heating, the boiler demand after diversity, at the neighbourhood level, is limited by household heat loss. Most households have heat losses well below 20kW, so in practice the boiler is either cycling on-off, with a lower time-averaged power demand, or for modern modulating boilers will be running at something around house heat loss.
    When the space heating load is moved over to heat pumps, with CoPs of around 2-3 under worst case conditions and sized for house heat loss, the heat demand might be 8-10kW, with an electrical demand more like 3-5kW under worst case conditions.
    I suspect the key issue will be getting households to use the available generation and network capacity efficiently, to engage in some basic DSR, so we don't end up millions of households using their heat-pumps like a gas boiler, starting up as they get home. Charging their EV and running their appliances in the early evening, with all of this extra demand hitting the evening peak.
    Britain should also be more outward looking, learn from other countries, start considering options like the French approach of having standing charges based on network capacity, and more time of use tariffs, to give households an incentive to use the electricity system efficiently to keep costs down.
  • A good starting point would be to look at how countries which already have this problem and have been dealing with it for many decades, manage it - so look at Southern Europe around the Mediterranean, some of the US utilities in the hotter states. They're all ahead of Britain on this topic because of their existing climatic conditions. A few observations I would make:
    Firstly, we don't want to be pouring money into network and generation infrastructure to meet peak cooling, or heating demands, that lasts for short periods, resulting in under-utilised assets, high costs to businesses and consumers and exacerbates our already high electricity costs. We really want to be aiming to use the capacity we already have efficiently, so that leans towards solutions like flexibility / DSR, where competitive.
    Many of those countries are ahead of Britain with their smart metering, and are also ahead of Britain on their time of use tariff offerings, with the hot countries typically having consumer TOU tariffs where the prices reflect the high costs of power and shortages of capacity during peak times for aircon / cooling demand, charging higher prices during the peak to incentivise people to shift demand to other times of day where possible. Compared to pouring money into upgrading networks or building peaking capacity, or even battery storage, DSR is generally the more economically efficient approach.
    In the US states where cooling demand is a major contributor to peak demand, many of their electricity suppliers operate Demand Control / Load Control programmes, where they can automate control of air-conditioning loads, to shut-down or turn-down aircon loads for short periods in response to grid demand, or local demand conditions to manage loads on the system.
    Now it's interesting that if you look at many aircon units and heat-pumps sold in the UK, typically the imported models, many have 'Smart Grid' capabilies already built-in, typically inputs to trigger the units to reduce or limit load, or shut-down, or in reverse to ramp-up demand by increasing heating or cooling. But of course, these are just control inputs and capabilities, to use them depends on the local country having some form of local or nationwide Demand-side Response comms infrastructure to provide the control signals, to connect into these heat-pump/aircon units - various other countries have these types of DSR systems in place and use them to manage these loads, for controlling aircon systems, heating systems, or other off-peak loads like EV charging.
    In Britain we're years behind these other countries, we don't have a system for providing DSR controls to household loads, so anyone fitting aircon today is almost certainly not going to have automated DSR in place. But it's an area where Britain really needs to catch-up and start getting this infrastructure in place, not just for cooling, but also for heating and EV charging.
  • we don't have a system for providing DSR controls
    There are some examples in the UK - e.g. Octopus's Agile tariff - together with a few gadgets (e.g. battery systems) that dynamically adjust according to the current (and future) prices. It is all very supplier specific though - there really need to be a generic supplier-agnostic system if it is to be taken up by appliance manufacturers in general. A obvious potential solution would be for appliances to be able to "tap into" the home area network (HAN) provided by smart meters - but that does seem to be closed (at least I've not seen any public specifications of now to listen in to it).
  • Yes to date the British supplier-led approach is non-standardised and highly fragmented, it needs a consistent, standardised way for appliances to interact with tariffs and receive control singals, that works across all suppliers and has a standard interface arrangement with the appliances.
    Using the smart metering system as a standardised, secure system to provide signalling for home DSR would seem a very strong option, and that's exactly what some countries have done. The French 'Linky' smart meter looks a great bit engineering, every meter has a transmit-only serial port, similar to RS485, that can have a hardwired or wireless connection to the meter, with the meter providing a range of control signals to the appliance and other data like live metered import, to allow dynamic management of loads (ramping EV charging, or heating/cooling up/down)  so as not to over-load the incoming supply So it also solves this issue around overloading the individual supplies to the property and needing to upgrade those.
    Unfortunately the SMETS2 British smart metering systems were never designed with these same capabilities, originally just the auxiliary load control switches (ALCS) or a home-area-network (HAN) controlled ALCs (on/off binary) and even that was badly implemented, as these capabilities are pretty much completely inaccessible to the home owner, or the installer fitting new appliances like heat-pumps, aircon, EV charge points etc.
    Again, the French got this correct, their meter was designed so that the comms is accessible, so the homeowner or the installer working on their behalf, can connect in their appliance comms cabling to the meter to get the loads working with their smart meter.
    It's a real shame Britain wasn't able to engineer a better smart metering system, as good as the French , and economically speaking probably has done quite significant harm to consumers from the various costs it then creates in needing to duplicate smart functionality in the home appliances and the very significant costs from unnecessary upgrading of distribution networks and home supplies that a decent DSR-enabled smart metering system could have avoided.
  • Thanks, I think you’ve raised some very important points.
    I completely agree that preventing overheating should come before relying on active cooling. Measures such as external shading, improved glazing, natural ventilation and better solar gain control should be the first line of defence. Designing buildings to remain comfortable without excessive mechanical cooling is clearly the most sustainable approach.
    Where I think the engineering challenge becomes interesting is at the distribution network level. Even if national summer demand remains below today’s winter peak, localised demand could still become significant in areas where many households adopt air conditioning or reversible heat pumps at the same time. Distribution networks are often constrained by local transformer and feeder capacities rather than national generation alone.
    I also agree with your point about generation. Heatwaves often coincide with high solar output but lower wind generation, so the future electricity system will probably depend on a balanced mix of solar, storage, flexible demand and dispatchable generation to maintain resilience.
    Perhaps the key question is whether our network planning assumptions and building regulations should begin considering summer peak demand as well as winter demand. If we start thinking about this now, we may be able to avoid more expensive reinforcement in the future while encouraging passive cooling and smarter use of electricity.
  • It’s also encouraging that many modern heat pumps and air conditioning systems already have smart-grid capability. The challenge now is developing the communications and control infrastructure to make full use of it. As cooling demand grows, this is an area where the UK has an opportunity to plan ahead rather than react later.
