AI & REWARDMAXXING: Part 28
Recommender systems and anomaly detection algorithms cannot, by themselves, remove historical bias because they are fundamentally designed to learn from existing patterns and identify deviations from established baselines.
Instead of automatically acting as filters for bias, these methodologies can become mathematical accelerators for it.
If you feed them historically biased data, they do not necessarily correct it—they can perfect it.
Recommender Systems and Anomaly Detection
Recommender systems (using techniques such as Collaborative Filtering or Matrix Factorisation) predict what a user may like based on their past behaviour and the behaviour of similar users.
Collaborative Filtering relies heavily on data density. It requires sufficient interaction data to identify meaningful patterns.
Because historical datasets may heavily favour Western media, consumer habits, and paradigms, recommender systems can view indigenous content through the lens of a “cold-start” problem.
The algorithm may infer that because a piece of content or a community-based solution has not yet been engaged with by millions of users, it has relatively low predictive value.
Recommender systems can also create Feedback Loops.
If an algorithm recommends Western-centric educational or financial tools to an indigenous student because “that is what is popular,” and the student clicks on the recommendation out of necessity, the algorithm may log that click as a positive signal.
It then recommends the same content to the next student.
This creates a digital monoculture that can actively suppress local alternatives, mistaking historical dominance for organic preference.
Anomaly Detection
Anomaly detection algorithms (such as Isolation Forests or One-Class SVMs) are designed to identify data points that deviate significantly from a defined baseline.
The critical issue is that the algorithm itself does not necessarily determine what is “normal”—the training data and modelling assumptions help define that baseline.
If the dataset consists predominantly of Western institutional, financial, and legal structures, those structures may become the mathematical reference point.
To an anomaly-detection model trained on highly structured banking systems—which may expect regular, predictable, and conventional deposits—an informal, trust-based community savings pool could appear anomalous.
The algorithm may flag it as suspicious, fraudulent, or high-risk.
Instead of removing historical bias, anomaly detection can therefore punish behaviour that falls outside the patterns represented in the training data.
It can label traditional, sustainable, and communal ways of living as “outliers” that need to be eliminated, corrected, or forced into the standard mould.
Conclusion
Instead of using Collaborative Filtering purely to maximise watch time or purchases, engineers can use Content-Based Filtering with Semantic Diversity Constraints.
Instead of simply tracking citizens to determine whether they deviate from dominant norms, anomaly detection can be turned outward and used to identify where the underlying system itself may be failing.
By changing what the machine considers a “success” and what it considers an “outlier,” these tools can shift from being enforcers of historical bias to potential defenders of sovereignty.
Day 28 / 30 of the #AlRewardmaxxing Series.
Tomorrow in Part 29, we'll dive deeper into reengineering algorithmic architectures for true equity.
What's your take? Have you seen Al algorithms flag legitimate cultural or local practices as "suspicious" or "outliers"? Let's discuss below!Point down
