New fire detection ???
Hi guys. I see there is a new code of practice for fire alarms. Iv not a chance to look into this yet and i wondered what were the main changes relating to domestic properties and new builds. Thanks guys
    • New recommendation that communal fire alarm systems should not normally be installed in purpose-built blocks of flats
    Is it me or does that sound potentially controversial?
    It is part 6 so already has limitations on number of stories (I'm sure that's plural of story but please correct if not!) and floor area, so what I think you may be alluding to Andy, never previously applied to this scale of construction.....
    BOD
  • So having been published April 2019, when are we supposed to comply with it?
    Andy
    perspicacious:
    BOD
    Not sure about controversial BOD - generally there has never been a requirement for communal fire systems in purpose built blocks  as there is basically no one to respond to a communal alarm (ie no concierge capability) and the methods of construction, compartmentation etc should all be in place (ie they are purpose built).
    It is true to say that a new breed of fire risk assessors are (or have been) driving this change to including communal alarms based on no real knowledge of what they are trying to achieve  - post Grenfell, the situation has now reached a frenzy of confusion
    I suspect the revision to the standard is just taking the opportunity to reiterate that there has never been a requirement - ie the flats are "defend in place" if properly constructed (and maintained)
    OMS
    See section 20, the document was published in 2012
    https://www.local.gov.uk/sites/default/files/documents/fire-safety-purpose-built-04b.pdf
    Parsley
