GRENFELL TOWER FIRE
The cladding was not fireproof but just fire resistant and the mistake was that the building regulations did not spot the difference quickly enough.  The survivors are looking for someone to blame but this is not appropriate as it was a mistake by the authorities not the design engineers..
BUT more importantly what do we do about the other buildings that are at risk; to avoid another disaster?
Well, the fire fighters problem was that they could not get up above the fire and douse it or rescue the residence in the upper floors.
SO priority must be to remove the cladding on the tall tower blocks first and at the same time arrange for roof access for all residents in the case of fires.  Once the roof is a secure place then crane helicopters can be used to evacuate any residents that are unable to escape downwards due to the fire.
In my book, the loss of life at Grenfell would have been minimal if the roof had been equipped with a secure area, i.e a fireproof [asbestos cement clad] container on its roof.
Parents
  • I'm not a technical expert but have a lot of experience of the UK's Furniture and Furnishings (Fire) (Safety) Regulations; and would appreciate your views on what I believe to be a largely ignored contributor to the Grenfell Tower fire (for possibly obvious reasons). Specifically, in 2014 the Department for Business (responsible for the FFRs) went out to consultation on a new 'match test' that would have hugely reduced flame retardants in cover fabrics. At the same time, its research and testing had discovered that the current ignition test fails in practice up to around 90%, i.e. UK sofas and mattresses are flammable when believed not to be so. The changes were and are being blocked by the chemical and furniture industry. Under media pressure the Department went out to consultation again in 2016 with the same proposals. However, it is refusing to comment on the consultation returns or say when or if it's going to make safety changes. In the meantime - as demonstrated by the Hull/Stec paper in Chemosphere in December 2017 - a typical UK chemically treated sofa is more dangerous than a non-treated EU sofa, because it gives off vastly more toxic fumes such as hydrogen cyanide almost as soon as it catches fire. All of which means, logic suggests, that the Grenfell Tower fire was a) more toxic than it needed to be, if the Department had made changes in April 2015 as originally proposed, and b) mostly made toxic by burning flame retardants in furniture, not cladding. While cladding was obviously toxic, most of the fumes/smoke would have stayed outside the tower. Once furniture inside it caught fire, the result was huge amounts of toxic fumes/smoke - and it's this that mostly killed people, not cladding effects.
    While that does sound like a cause for concern, I'm not sure it would have made a huge difference in the Grenfell case. Had the defend-in-place strategy been properly implemented then neither fire nor smoke should have been able to escape from the flat what the fire started into the rest of the building - after all each flat should have been its own fire compartment all front doors were meant to be fire doors, presumably with the usual intumescent draught seals.  For sure, unnecessarily toxic smoke is not great especially for the occupants of the flat where the fire started, or the firefighters, but as I recall the occupants of the flat where the fire started survived.
Reply
Children
No Data
