Old Transistors.
This subject falls loosely under the heading of wiring, so please forgive me if you are expecting to discuss kA and kW. There again some equipment may still have old transistors in it.
I have become addicted to renovating old radio cassette recorders. It has become an obsession. I saw a model advertised on fleabay that I used to own and had disposed of. I bought it with a view to renovating it and enjoying past listening pleasure with some old comedy and music cassettes.
The Philips cassette recorder is a model N2205 and just pays and records on compact cassettes. It is an early 70s model. The motor speed control will not adjust correctly and the player plays at odd speeds. Also the sound output vaires and I have to bang the machine to achieve full sound output sometimes.
The circuit boards use tin cased/ canned AC127 and AC128 transistors which I believe suffer from internal whisker growth that can cause shorts internally.
Are there any plastic cased transistors that are equivalent these days please?
Parents
  • the sound output vaires and I have to bang the machine to achieve full sound output sometimes.
    Sounds suspiciously like a dry joint or a cracked PCB track to me.
Reply
Children
No Data
