How much to charge for EML and smoke alarms in small hmo
Hi all,
I'm enquiring has to how much people usually charge to retro fit EML these will be supplied as two radials (ground and upper floor) from the fuse board located under stairs, the cable will be surface ran and housed in white PVC trunking using steel fixings within to support the cable. The smoke alarms will be cabled in a similar manner as the existing ceiling roses only contain a switched live feed, a provision for a new circuit will be made here, these will be interlinked and sited to meet grade D1 category LD1.
I could do with knowing what members think is a fair price per point for the above which is basically going to be installed into a 3 bed house converted to a small HMO.
LED EML and Aico interlinked with battery backup. I don't expect anyone to give me exact pricing but in the region of would be helhelpful.
Been told by client that my price was almost double than what he had been quoted so it's got me thinking, I asked him for the competitors quote so I could do a comparison, quantities etc and he came back with a figure of £1500.00 for the following:
Fuse board change
EML
Interlinked smoke alarm
The last two item are unknown quantities.
​​​​​​From our survey they would look like this:
Fuseboard 5+5 RCD split board
6Off LED bulkhead EML
9Off smoke points
Sorry forgot to mention the prospective client failed to supply us with the competitors quote which got me thinking if they were trying to pull a fast one.
I did post this in the ask the community section but due to the lack of replies assumed I'd posted in wrong section, sorry for the double post.
Ts
  • Does London weighting apply?
    Andy B.
    No, job based in the Midlands.
    ts
  • Timeserved:
    Hi all,
    Fuse board change
    EML
    9Off smoke points
    Ts
    Your price seems very reasonable.
  • If they are ten year lithium battery alarms there's £500 for starters.
    Sparkingchip:
    So you'd price at £55 ea?
    Apologies error in original post there are 10 Off smoke alarms.
    Just to be clear our cost for the complete solution was £2195.00+vat.
    Does this seem reasonable?
    Ts
  • https://www.tlc-direct.co.uk/Products/EI166E.html
  • Your price seems very reasonable to me.
    For a small top floor flat, I saw a customer's quote from an alarm company in my town last week, and they quoted £99 + VAT to install each smoke alarm (for what i seem to recall were aico 140 series), wiring simply installed in the loft.
    Sparkingchip:
    Hi Sparkingchip,
    Thanks for the link, this is why the clients other quote cough, cough has not been forth coming.
    I don't mind sharpening the pencil every now and then, it's just when they come back and tell you that your quote is almost double they need to be backing up their claims, btw if this was true then I'm not sure why they would waste their time on me ?.
    I think I will stand my ground on this one ?.
  • If there is another quote, perhaps has a much lesser scope- no board change or fewer sensors?
