psychicwarrior:
John Peckham:
The problem comes with the sticky label to indicate the date of inspection and the date of the next inspection. I would recommend to write in long hand on the label "shower circuit only" or whatever works you have done.
...I have a view on that 'sticky label', in that other than after a full rewire or new installation, that label should only be 'updated' following a the periodic inspection that it indicated (or perhaps if one is held earlier for some reason). EIC's issued for other things not those above, do not require amending the label... that way nothing gets out of kilter with the periodic inspection process (which that sticky label is all about really); carrying out some EIC work does not change that process.
