Sparkingchip:
Burglar alarm guys also regularly connected into the lighting circuit in the loft and dropped a supply into the airing cupboard, they tend to be less than impressed when they don’t find a permanent live in a light ceiling rose.
That's why I hold the view that there should be a separate circuit for a burglar alarm even if it has battery back up.
Arran Cameron:
wallywombat:
Arran Cameron:
That seems to be a bit of a non-sequitur. If the alarm installers are disappointed that there isn't a nearby permanent live on a ceiling rose to steal from, they would be even unhappier if told they had to install a whole new circuit and run a cable back to the CU.
I can see an argument for not having a dedicated supply, unless the unit is capable of indicating the supply has been removed.
For example, smoke alarms that silently switch to battery may be better on a shared low current radial such as lights, as they are then less likely to trip and then be switched off and forgotton.
Arran Cameron:
The ceiling rose junction box with its loop-in wiring is now really showing its age and is no longer a practical (or even safe) installation for most residents who wish to install fancy light fittings. It is still, however, the most common arrangement for new build houses and rewires, probably as the result of the electrician's training and how they consider it to be the norm or they cannot think of (potentially better) alternatives.
So, what is the best way to wire ceiling lights? Should neutral wires be taken to the switches or not?
