Chivers:
I've never thought of Roses as being unsafe, they seem fine until people start trying to terminate more cables into them than their design or do you mean working on them at height?
Most modern light fittings are designed for a ceiling with just one cable. Rarely is a terminal strip incorporated in order to replicate the terminals in a ceiling rose. Therefore the installer ends up having to use a chocolate block to make the connections. More often than not there is insufficient space in the light fitting to contain the chocolate block so it ends up being shoved into the ceiling cavity with exposed live parts. A very shoddy and potentially dangerous arrangement.
There is also the controversy of a permanent live terminal in a ceiling rose.
Alan Capon:
I agree, looping in to a ceiling rose is by far the most common, and probably the cheapest.
It might be the most economical when it comes to twin and earth cable but the savings are likely to be minimal over other methods as around 90% of the cost of a new installation or rewire is labour rather than parts.
I rewired the lighting on my house using Surewire light and switch junction boxes in a more radial than loop-in topology. It's quite an elegant arrangement with only one cable to the light fitting and one cable to the switch, but are there any better methods? It has a notable disadvantage that it doesn't supply a neutral to the switch.
An electrician criticised my unconventional rewire with 'large' junction boxes under the landing floorboards and asked why I didn't just use loop-in wiring with ceiling rose junction boxes. I replied that I hold the view that ceiling roses should be easy for residents to replace so they should not contain a complex and intimidating interconnection of wires where connections also affect downstream light fittings as well as the one in the room. Also the potential health and safety issues with working with complex wiring at a height whilst looking at it upsidedown. He still wasn't convinced and thought that I was wasting my money on the junction boxes and an extra few metres of cable, as ceiling roses will do the job just as well, as well as confusing electricians in the future who expect to see loop-in wiring.
ebee:
"There is also the controversy of a permanent live terminal in a ceiling rose."
What controversy is that then?
It's not obvious to installers of light fittings, in the same way that a permanent live terminal at a switch is, unless they have knowledge of how loop-in wiring is connected. There have been cases of installers of light fittings receiving electric shocks because the lighting circuit was not switched off at the consumer unit even though it was switched off at the wall switch.
Both loop in at rose and loop in at switch have their merits and demerits. That junction box idea is OK if it is in an eaceesable place, say by a loft hatch but under floorboards is a no for easy alterations.
The Wiring Regulations (does anybody know which edition?) do not permit a junction box with screw terminals to be installed in an inaccessable place or underneath floorboards unless they can easily be removed for inspection. I assume the same applies to chocolate blocks with screw terminals shoved into the ceiling cavity. Junction boxes with spring clamp terminals are permitted for installation under floorboards as they are deemed to be self tightening and maintenance free.
Stop manufactures making daft light fittings. 4 terminals and room for three (T & E) cables should be the minimum
Light fittings are now designed and manufactured for the global market rather than for the peculiarities of British wiring (which also explains why most recent models are Edison screw rather than bayonet cap) so often only have terminals for one cable rather than three. Even plenty of older British light fittings and decorative ceiling roses are no different.
Are there any countries, other than the UK, where loop-in wiring with ceiling rose junction boxes is commonplace?
We're making some changes behind the scenes to deliver a better experience for our members and customers. Posting and interactions are paused. Thank you for your patience and see you soon!
For more information, please read this announcement
