wallywombat:
A few years ago I was in the fairly crowded departure lounge of a small Irish airport (think 5 gates of which about 2 in active use), when the fire alarm sounded. Absolutely no one reacted or evacuated. I made sure I was near a fire escape door that led directly outside, but didn't actually evacuate. The thing that really surprised me is that none of the staff seemed to know what to do. I had assumed they would either be encouraging evacuation or assuring us it was a false alarm, but they just quietly ignored it too.
wallywombat:
Chris Pearson:
....a fire extinguisher is no use at all ...
these were not fires but were the alarms reacting correctly (twice through someone in the restaurant at breakfast burning toast activating an alarm and at least once due to a resident leaving the bathroom door open while showering). The fact that this was 100% correct functioning of the detectors is a pretty high success rate.
To most people that would be interpreted as a 100% failure rate, and adds to the intuition that most fire alarms can indeed be safely ignored. This is very dangerous.
A sensor that cannot tell the very significant difference between burnt toast or steam and a real fire, is not making the correct decision, or is the wrong sort of sensor for the location. However, the price of making the sensor less sensitive is to mean that occasionally a real fire will not be detected, or more likely, will be detected later. That is the risk balance.
mapj1:
