mapj1:
And the most common case, for false alarms, you may as well remain in place.
OMS:
I've put people on disciplinary warnings before now for adopting a "cavalier approach" to drills or false alarms - and I'm deadly serious about it. I accept that most people don't like being told what to do, but need telling for their own good. If nothing else, it shows that people understand risk and demonstrates the correct behaviours in a safety culture. For me, a guy who can't react sensibly to a warning system, is probably not safe to be acting as a designer.
Chris Pearson:
Ignoring an alarm wouldn't have gone down well in a military establishment where we had role calls so nobody could pretend not to have heard.
Sure - you have a well trained population used to giving (and receiving) instruction and a structure that can enforce and reinforce procedures - bit like a school or hospital. It's the ill disciplined civpop that cause the problems
One slight snag was the sound-proofed audiology enclosures which were so good that the alarms could not be heard. That simply required somebody else to go and open the door - no use knocking! ?
If they are anything like the audiology booths in medical facilities, we used a flashing red light inside the booth. Similar for soundproofed and or EMC screened enclosures so our lady in Beijing can chat to Whitehall (or they have a window from which you can see the beacon outside, if you want to avoid taking what is potentially a black probe into the red (or blue) zone.
To be honest I don't know what the routine is in classified areas - you wouldn't normally even leave your desk if highly sensitive materials were in use. But there will be a risk analysis somewhere.
Sure - alarms don't usually mean automatic immediate evac - there will be investigation delays, zoned or phased evacuation depending on the location within the establishment or displacement to secure and fire sterile refuge areas (just remember to "Windows" and L on the PC ? - or more probably remove the brick and stick it in a Manifoil Mark IV) - but as you say, it will be a well developed procedure adopted by trained and disciplined people - if you don't follow the rules, it will be an interview without coffee
Chris Pearson:
Alasdair Anderson:
Classified areas will generally have access control, normally through a card swipe or keypad to open the door (to get in at least). All doors are automatically unlocked when the fire alarm sounds so that people can escape rapidly (which means if you want to get in, just set off the fire alarm or wait for the weekly test - I know it works as I have tried it, but only with rooms I had access to anyway and only with the weekly test).
Not necessarily true - there are all sorts of establishments where doors do not unlock in the event of a fire - but you absolutely need adequate procedures in place to manage the risk of people effectively locked in a building (or sector of a building) - you need to think prisons, hospitals, cash handling and other banking facilities along with a whole host of other secure facilities.
Having said all this, I realise that we are suffering from a bit of topic creep here. I am not sure what this has to do with cable fire performance. Any comments to bring it back will no doubt be welcomed by Lisa.
LoL - teachers pet ?
Alasdair
Alasdair Anderson:
seconded. Either for security to stop unauthourised folk getting in to see something, or because what is in the room is dangerous, and should never be let out.
There are also systems for places where you do not go in to rescue someone, because it is a waste of time, and would involve the loss of additional lives.
