Sparkingchip:
I have worked in houses where the ring circuit has been wired through the floor void with the ring supplying the first floor sockets in the bedrooms and every ground floor socket being wired as a spur from a first floor socket above it.
That absolutely minimises the cable used, but it means there is not a socket in the house you can connect another spur to and the number of spurs equals the number of points on the ring.
So to add another socket or spur you have to cut and joint the ring to extend it from upstairs, wherever the new point will be located.
Andy Betteridge
ebee:
"So how do you make a branch in a radial? "
From an existing point is often possible and worth any extra work usually
Chris Pearson:
Sparkingchip:
Any circuit with junction boxes is a nightmare if fault finding has to be undertaken, there is rarely a reason why a domestic socket circuit should be wired through junction boxes from new.So how do you make a branch in a radial?
