But not a safe assumption when dealing with existing as earlier rules permitted two (single) sockets on the same spur - so two cables at one socket could still legitimately be a spur (never mind later instances with less legitimacy but just as much actuality).
Zoomup:
ebee:
Which would be 2.5 T & E ?I always assumed 2.5mm2, but "a current rating of not less than that of the conductors forming the ring" implies 5.0mm2 does it not?
mapj1:
No, I think the intention is always that the spurs are wired in the same stuff as the ring, namely 2.5mm. IF you had 4mm radials the 2 socket limit would make no sense.
In any case the rating of 2.5mmsq is 27A for surface wired or in plaster - which would have been the options when it was being dreamt up. Dont forget that part L and all this thermal stuff ony go t going after the 1984 revisions to the building regs - because until you have central heating the indoor and outdoor temps in all rooms without a fireplace are not so different.
ebee:
I altered a kitchen wiring of a rewire I did a few years previously, single sockets for washer and dishwasher with dp switches above worktop, all labelled. one heavy load each spur not washer and DW in one twin. This gives easy switching of W & DW and negates the simplyawfull practice of sockets in cupboards. I`d never encorouge two such loads in one twin.
Same reasoning I always use a 45A DP switch for cooker, not one with onboard socket, that is a throwback to the days of not many sockets per dwelling and OK for kettle now and again but how often do washers/dryers get a home there? Aghh.
