mapj1:
why can house and garage not share the one big fuse? It will never blow unless there is a dead short in the bit that would have been split tails otherwise.
AJJewsbury:
Another possibility might be a 3-phase switchfuse - but using a single-phasing kit to put all three fuses on the same phase - but last time I looked down that road it was going to be rather an expensive approach ...
Cos
(1) that would require a JB downstream of the fuse, which wouldn't be easy to fit, so may as well have two switch fuses; and
(2) the branch line would have to be 16 mm2 which would be overkill.
Sir has deeper pockets and shorter arms than a Yorkshireman.
mapj1:
Cos
1) So you cannot fit two cables to one switch fuse ? Or an adaptable box and some line taps?
2) is the max demand in the garage so high you'd need the full fat cable size - if only 32A breaker and 6A lights, then some 6mm would do so long as S/c protection is OK.
