Smoke alarms, are they appropriate.
Part of the communal areas of purpose built sheltered housing flats on three floors with a lift that has a full monitored fire alarm system, that closes the internal fire doors and opens the exterior doors when activated.
Each individual flat has a heat alarm in its hallway connected to the communal alarm system and also has an Aico interconnected smoke and heat alarm system that is connected to the intercom system allowing the call centre to monitor them and speak to the tenants to ask why they have been activated.
Can you think of any justification for installing very basic domestic battery operated smoke alarms in the communal areas?
Because I cannot think of any way their installation can be justified, particularly as they will not be monitored in any way and should not be required.
Andy B
Parents
  • Pardon if I seem a bit naïve:
    My understanding is that the prime purpose of a self-contained, battery powered smoke alarm is to alert sleeping people to smoke and the possibility of a fire.
    There is not a strong case for them in a place normally occupied by conscious people, to whom the presence of smoke in the immediate vicinity would be obvious.
    There is even less of a case for them in areas not normally occupied.
    In a corridor serving bedrooms, as described in the original post on this thread, we can make a case for them. But with a very-robust and sophisticated alarm system already in place, they seem to be the piece of string that backs up the belt and braces.
Reply
Children
No Data
