davezawadi:
Of all the questions....
This should not really be a problem, but there are a few things which can help:
1. Use DI boxes with the ground lift activated and balanced inputs.
2. Set the mixer input gain correctly and use the input compresser / limiter at just above the normal playing level in limit / sharp knee mode
3. Train the musicians properly so that they don't pull plugs out while performing, and charge them a bottle of something if they do!
4. Stick any loose cables in place with gaffer tape, or locking clips if fitted.
5. Be ready to use the channel mutes quickly.
You may need something a bit more fancy by way of mixer etc. for the above, depending on what you have at present. However this is all part of the skillset of the "sound guy"
Happy new year
David
davezawadi:
OK Z, you have to go to the next stage. In reality the sound guy is as important as all the players (although some are not treated as such and are often seen as unnecessary by amateur groups) and can have a huge influence on the overall performance. There should be no need to unplug your "electric" violin, if you play more than one instrument some adjustment may be needed, and the best option is a switch which shorts out you instrument microphone, or if it is phantom powered shorts the two signal conductors together. This should be electrically silent, just stopping the mic from picking up the stage sound.
However in the general case I would suggest you find someone who can be your sound mixer, he/she will probably be musically trained or knowledgeable and will work on making your band sound similar in each venue as well as dealing with changing instrument levels and the musical balance as it changes through various pieces from an artistic viewpoint. This process makes all the difference, even with a simple Ceilidh band for barn dancing. As far as equipment goes you may find that a suitable person already has something like an M32 (or cheaper X32) digital mixer which they will provide saving you money for the modern sophistication and a lot of facilities you probably don't have (including the effects and compressor/limiters etc referred to above. I can think of nothing automatic which is available, but then your problem is normally minimised / avoided as I suggested above. The M32 does have several automated features which might help you, but one would need to see the exact problem first, having done the other suggestions.
David
M. Joshi:
There are 1/4" plugs available that automatically mute when they are removed from the instrument. Here is an example of one from Neutrik:
https://www.neutrik.com/en/neutrik/products/plugs-jacks/plugs/professional-1-4-plugs/silentplug
This company can make up custom cables with the connector and the length and type of cable you require:
https://custom-lynx.co.uk/product-category/microphone-guitar-instrument/guitar-instrument-cables/angled-jack-to-jack/
