mapj1:
are you asking if you can free up the LN going in an and out ?
If they both come from the same direction, and assuming you do not need a neutral at the switch for any reason, the neutral junction could be elsewhere, potentially freeing up 2 cores.
It is not clear from you description if you intend to keep the 2-way functionality. If you do not need this either you could free up the 3 core as well
