Wiring diagram
Anyone out there with a great mind for heating systems, care to draw me a wiring diagram ?
There is a
-warm flow oil boiler
-Immersion
-pipe stat
-UFH Valve
-Manifold(8 zones)
-Hot water valve
-Hot water circulation
-Towel warmer valve (stat is what’s on the towel rail)
-Upstairs heating valve
-2 x 2 channel Honeywell programmer
-1x 1 channel Honeywell programmer
-1x stat for upstairs radiators
-stat for each ufh zone
Any advice on what I can use to get this all linked together, currently looking at S plan but I feel someone with experience with similar system  may give some better guidance
Clint
  • I presume that the "immersion" is a type fitted into a copper cylinder to heat the water in it. It will need a 16 Amp supply and a local 20 Amp double pole isolating switch (with neon indicator is good). Its removable thermostat will be inside it and is an adjustable long rod type contained in a special pocket. It is connected by heat resisting flex.
  • Chris Pearson:
    . . . An alternative approach is to have the towel rail on the heating circuit, but no TRV. You wouldn't want them all to close, would you?
    It is usual to have a bypass to protect the system if all valves close before the pump / boiler has stopped. This could be either a mechanical bypass, or a radiator used as a bypass, often either in the bathroom or a wet-type towel rail.
    Alan.
