The guides couldn’t explain to the kids why they lit.
I suppose they could not explain why you need a larger gap between the high voltage wires then LV ones either ?. (as it is the same reason)
It is a bit worrying that no-one thought it necessary to fill in their knowledge gaps and find out.
They also make quite good detectors of large RF fields as well - if you walk up to an HF transmitter holding one and it lights in your hand, it is time to think about not getting that much closer.
