No such thing as a silly question! With a long transmission line, you get a phase shift along its length due to its reactance. This exact phase shift is a function of distance, as well as load. If youHave a second cable of a different length, it is likely that the difference in phase (even though the frequency is the same) will prevent you from being able to close the second end. The solution is a dc link, with the “inverter” in synchronism with the local grid connection point.
