1/ if connected to a plug, is this covered by part-p?
(and I probably can't get a biased switch which will fit in a 'normal' domestic switch arrangement)
But whatever I do, the colours of the cables will not completely represent their function - e.g. if using 3 core flex for the opener, then the earth would be used for neutral, and that seem very BAD to me.
Since the biased switch is assumed to be DC (and I probably can't get a biased switch which will fit in a 'normal' domestic switch arrangement), I'm thinking that it's wise to run separate wiring for the switching of live for the lights and the DC switching. Am I right to think it's not good to run them in the same multi-core cable, or just paranoid?
When looking at available multi-core cable, (e.g. on CPC), most is quoted as 'control' even though rated good enough for what I need (1mm sq, 300v?), is this just because it's not std colours?
Is colour important if all wires are sleeved red at the switch?
| Yellow/Green |
| Blue |
| Brown |
| Black |
MHRestorations:
With ref to the oversleeving... I am of the (controversial) opinion that brown/black/grey are all phase colours, and do not need oversleeving. (I DID oversleeve the blue back before 2005, because of the possibility of confusion with a neutral)...
Why do brits always think live should be brown? The existence of 3 phases is not a mystery to most?
