Why did the green communities change the term from global warming to climate change?
Simply because the climate DOES change by the second?
Somewhere on the planet it is daytime, somewhere it is night time, somewhere it is raining, somewhere it is snowing, somewhere it is sunny, somewhere it is winter, somewhere it is summer.
alanblaby:
Either way, I havent heard of a new ice age coming, rather exactly the opposite, the polar ice shelfs are melting rapidly.
Paul Judd:
Is the formula for calculating the maximum neutral current (Im) in Annex A722; A722.1 Neutral current of a three-phase installation, actually correct?
There's an L missing (IL3) and only half of the final multiplication is shown.
Probably!
Protective conductors and exposed-conductive-parts downstream of a protective device provided for the purposes of (iii), (iv) and (v) shall have no connection to:
(a)any protective conductors or exposed-conductive-parts of any circuit not protected by the same protective device; or
(b)any extraneous-conductive-part.
well, given that you cannot bond exposed blades of grass, or the surface of the flower beds, which are equally touchable and tingly to bare feet, some things are best left to float to local terra-firma potential, and anything planted in it that is short, like a fence post is probably best left alone.
I note and concur with the 25V maximum exposed voltage instead of 50 instead of 70
