AJJewsbury:
Paul Judd:
Is the formula for calculating the maximum neutral current (Im) in Annex A722; A722.1 Neutral current of a three-phase installation, actually correct?
There's an L missing (IL3) and only half of the final multiplication is shown.
Probably!
Good question - it's also nothing like the formula in BS 7671:2018 yet doesn't have any change bars...
AJJewsbury:
I note and concur with the 25V maximum exposed voltage instead of 50 instead of 70
The thinking behind the 25V was that that earth leakage currents can raise a TT earthing system significantly above true Earth potential - so in theory an ordinary TT system could be hovering at anything up to 50V from Earth without the RCD tripping. An adjacent charge point might possibly also be at 50V - but there's no guarantee that the leakage currents are in phase - so you could have 50V x √3 between two adjacent TT systems on different phases - or even 50V x 2 = 100V if they're supplied from different sides of a split-phase supply. Ensuring the RCD trips above 25V was just intended to ensure the touch voltage between any two adjacent point couldn't exceed 50V rather than looking for a lower limit as such.
Of course with a typical 30mA RCD and a 200 Ohms electrode we'd be looking at about 6V per system or 12V max between adjacent points - so in practice it's a lot safer even than that.
Somewhere on the planet it is daytime, somewhere it is night time, somewhere it is raining, somewhere it is snowing, somewhere it is sunny, somewhere it is winter, somewhere it is summer.
Made me think of the Seekers - Morning Town Ride (starting at the bit I time-linked to ... the following verse at 1:24 starts "Somewhere it is night time, somewhere it is day ...").
Sad, I know ... something my Mum used to sing to me when I was a toddler, and we sang to our kids when they were toddlers ?
gkenyon:
Chris Pearson:
gkenyon:
Sad, I know ... something my Mum used to sing to me when I was a toddler, and we sang to our kids when they were toddlers ?Splendid - not even the New Seekers!
Back on topic, all the above confirms my belief that the situation has become, or is being made too complicated.
And what of 3-phase? Let's say that you have 3-phase at home and do your best to balance the phases. Whilst the car is charging, the phases will be sufficiently balanced to keep the neutral voltage down; but when you plug in or disconnect, the same does not necessarily hold true.
gkenyon:
Chris Pearson:
And what of 3-phase? Let's say that you have 3-phase at home and do your best to balance the phases. Whilst the car is charging, the phases will be sufficiently balanced to keep the neutral voltage down; but when you plug in or disconnect, the same does not necessarily hold true.In that case, 722.411.4.1 (i) clearly does not hold apply.
For larger installations, it may, however, be practicable. There will be additional guidance, and a rule of thumb, to help make that decision, in the 4th Edition of the IET CoP.
Chris Pearson:
gkenyon:
Chris Pearson:
For larger installations, it may, however, be practicable. There will be additional guidance, and a rule of thumb, to help make that decision, in the 4th Edition of the IET CoP.That to some extent is my gripe. The amendment aims to deal with the risk in single phase installations, but not 3-phase ones. There are spare ways in my fuse box just waiting for a solution. I suppose that one will arrive within the next 15 years. ?
Roger Bryant:
This thread shows an interesting perception of risk.
