gkenyon:
It is likely to be based on standard statistical calculations for MTTF, modified by an acceleration factor Af using the Arhenius Equation:
I've not plugged numbers in to check, mind ... you'd need to know, or search up, the activation energy of the type of LED junction you were considering to do this. Basically, this is the forward voltage drop of an individual LED at the point the LED turns on.
