its been called TN-S TNC-S and TT
That's a full house on the Earthing Bingo card.
I'd respectfully suggest that anyone who thinks it is TT should be demoted straight back to only changing light bulbs.
A Private Neutral Bond like this can only be TN-something. The decision as to which depends if normal load neutral currents and earth fault current share part of the path to the electrode - which can only normally occur where there is more than 1 NE bond.
And by the way if you do have 2 NE bonds, it is only illegal on the consumption side, the "distribution" bit is fine having bits of TNC - normally by it reaches any sort of load with a neutral connection, we should be in the 'S' part of the TNC-S, and then having parted, never shall N and E meet again.
This one NE bond thing most commonly comes horribly unstuck where there are UPS, mains and Gensets to consider, and any one of them may be the sole source, especially with US sourced kit, as in their world, the distinction between N and E is a bit less clear.
mapj1:
If it is pre 1980 Print a card in red ink on white background, or later than that black ink on yellow background like the service cut-out stickers you almost never see.
for the door to the equipment, that says any one of these ,
and watch all contractors copy it faithfully onto the test sheets from now on. The reports will be consistent at least.
