Memory Lane!
Reflecting on the 43 years I have been working in the industry and all of those once familiar famous brand names, I began to wonder what happened to them - apart from globalization, but where did they end up? Who bought out who? And who just gave up and shut down completely?
Here's a few names to start the ball rolling -
Allen West, makers of contacters, motor starters and switchgear.
Ellison - motor starter, switch gear etc.
MTE LTD, contacters, isolators, switchgear etc
What happened to these companies? Where are they now?
We all know that the likes of Electrium and Schnieder pretty own everything these days - Square D, Telemechanique, Merlin Gerin et al
But whatever happened to those old faithfuls whose kit I installed and worked years ago?
Parents
  • MHRestorations:
    Re: Pyrotenax... had no idea they were once separate companies.  When I trained in the 80s, the stuff was definitely branded BICC Pyrotenax, so I am guessing BICC borged the other company?
    I remember some PFC gear (long in the tooth in 1989) labelled "British Insulated Callender's", who then became BICC
    And less to do with power distribution but a well beloved name... Gent and Company of Leicester.   Manufacturers of alarm bells, fire alarm systems, switches, 2 different types of master clock system etc...
    Yes, BICC started to make MICS in competition with Pyrotenax. It matched standards very closely and claimed inter-compatibility (the gland of one make would fit the cable of the other, etc.). In due course, BICC took over Pyrotenax and acquired the right to use the brand name.
    I remember Gent well, and its rival, Synchronome. We had a Gent synchronised clock system in a building where I worked. Sometimes the slave clocks, wired in a series loop, would go out of synchronisation. The solution was to first clean the contacts on the master clock. to effect a clean make and break. Each slave clock had two static terminals on the front. If you short-circuited these terminals, the slave would ignore the next half-minute pulse; by this means a clock that had gone fast could be put back in synch. A battery touched momentarily on the terminals would step the slave clock forward by half a minute.
    Such fun!
Reply
  • MHRestorations:
    Such fun!
Children
No Data
