If I run an earth cable to the switch from one of the lighting circuits, would I also need to run one from the other lighting circuit incase at some point later on the first lighting circuit is removed for some reason, leaving the other circuit live but with no earth at the switch?
Baldyhugh:
So just to clarify either of these methods below are acceptable when coming out of a steel trunking in a single hole in plastic conduit to a plastic box and switch;
Just line/switch line and earth to switch position for both circuits
Line/neutral/earth in and out of switch position for both circuits
Thanks in advance
mapj1:
I'd be tempted to suggest, that for the purpose of the switch, an earth may be as simple as a short ink to the trunking. It is then not removed with the switch wiring. It is always possible I have the wrong mental picture of course.
