Tool kit 1956
The NJIC rule requirements for an electrician's kit of tools in 1962 (unchanged from 1956) was:
Ratchet Brace and set of bits
Large screwdriver and one small
2 pairs of cutting pliers
2ft or 3ft rule
Adjustable hacksaw frame
Pair of 7-in Footprints and 1 pair 9-in ditto
Bradawl
Wood chisel
Pad saw
2 Hammers
Plumb bob and line
Knife
Spirit level
Tenon saw
Centre Punch
Wheel brace
Pair side cutters
Set of spanners 1/8" to 1/2" Whitworth
Set of box spanners 1/8" to 3/4" Whitworth
Adjustable tap wrench
Miniature 6-in hacksaw frame
2 cold chisels, small and large, or (where appropriate) 1 cold chisel and 1 tonguing chisel
I have the wage rates for 1962 of 6/4 1/2d (now 32p) an hour with an apprentice at 15 on 20% of this, at 16 on 25%, at 17 on 30%. at 18 on 45%, at 19 on 60%, at 20 72.5%......
Sometime, I'll price the tools up from contemporary catalogues and in the meantime, have a think about how many weeks it would take to buy the tools!
BOD
  • For interest, the Bank of England inflation calculator shows £1 in 1962 was worth £21.50 in 2019  ( Inflation calculator )
    so 32p is more or less £7/hr.
  • No test kit ? not even an indicator lamp for live or bell and battery set for continuity ?
    But of course,  two hammers, ah, in some ways  little has changed, plenty of folk still use hammer to get the electrons to go the right way.
  • Two screwdrivers - no cross-point ones in those days. ?
    I am a bit surprised that there were no BA spanners in the list.
    Regarding the cost, wasn't father expected to stump up?
  • That looks pretty much the kit I was given on my first day as an apprentice in 1979, apart from the spanners being a mix of metric and imperial. The cost was then deducted weekly from my wages for about six months!
    I can't remember the prices though.
    regards
    Hi Bod, what tools/equipment would you recommend as being as being essential for an electrician here in 2020 in addition to those of 1956?
  • That list is for what would be called here (Switzerland) an electrical installer. Their would be different lists for a electrical technician, probably with test equipment, and an 'automaticer'  who would work with drives, PLCs, etc
    Best regards
    Roger
    Well WB, some of the existing kit would be largely redundant now, but it is difficult to draw a line these days with the shorter life expectancy of the inevitable battery operated tools used by trades and their initial and replacement cost.
    As to what the employer would provide to enable more productivity and the tradesman (sorry Kerry and Zs!) uses is debatable. If your employer didn't supply you with an impact driver, would you persist and use a screwdriver or would you use your own "home and foreigner" kit? I doubt if I would have needed three carpal tunnel operations (and resisting having a fourth) had I an impact driver years ago.
    An obvious addition would be PPE and a means of proving live/dead as suggested above.
    Missing from the original list is some means of "Rawlplugging" but joist drilling and chasing is expected, along with horizontal spirit level and vertical plumb bob.
    This leads onto the use of an SDS drill and for the cost, a laser level.
    As to actually testing the installation and certifying it, this has been a requirement since before 1927 (I'll look up actual date but supper is calling) and 1939 respectively. I'd respectfully suggest that even if the test kit and forms were available from the employer, few employees would either know how to use it or be able to compile an EIC so possibly academic.
    BOD
  • Power tools etc were the employers responsibility.
    Over the years the trades have ended up buying and supplying tools particularly power tools because   initially they can earn more money because they are on price work, but then gradually the pay rates settle back and they cannot earn a regular wage without all the additional gear. Eventually it got to the stage where often  the trades are being paid less than it would cost the employer more to hire their tools from a hire shop than they are paying in wages.
     Andy Betteridge
  • Looks about right for the tools I used at that time. I started as an apprentice for EEB and to their new 'prison camp' at Harold on the Hill in 1962 complete with rail travel warrants and digs (I wonder what happened to Geoff Palmer I lodged with?)
    There we did wonderful things like filing a piece of metal flat but like everything there, it had a sort of use as later a few holes had been drilled of different sizes to produce a drill gauge. Then there was a set of ‘footprints’, a spanner, a hole punch etc. We ended up even making a cantilever tool box but the bottom rusted away about 20 years ago for some reason.
    After about a year most went home but I got sent to the cable jointing school at Shoeburyness for some reason for a month before being released, going home and let loose to be ‘trained’ by a select group of ‘sparks’.
    I suppose the biggest memory was Freddie Finch actually getting over £10 in his wage packet with overtime just using a hammer, a screwdriver and pair of pliers. He did have other tools but I never saw them get used! That was about 1965.
  • mapj1:
    Being an electrical apprentice in Stewarts and Lloyds - the Scottish steel industry, we made our own from thick tufnol sheet, drilled to accept 2 series connected lampholders with 240V, RS pygmy lamps for up to 440 Volts. The 2 test prods were rubber flexible cables, tufnol tubes and brass prods, the cables were soldered into drilled holes in the prods for handles; we took pride in the making of these. As apprentices we moved around the 8 off DC and AC steel plants of Stewarts and Lloyds in Scotland, and for a 5 year apprenticeship!. The first time I came across a fused, Line and Neutral office supply and had to find out!
    Jaymack
