Posted by Arran Cameron on Mar 15, 2020 12:07 pm
Another argument is having the MCB for the lighting circuit in the room of the CU at the far end so you can easily feel its position when it trips during the hours of darkness.
Jaymack:
Back to basics, a torch or an emergency light at the Consumer Unit would serve the purpose. No one should be feeling around a C.U., what if there are missing blanks?
Jaymack:
Sparkingchip:
I have installed economy seven consumer units with alternate ways left empty to allow the MCBs to run cooler.
Andy Betteridge
A holier than thou and a cavalier attitude. Being economy 7, there would be long periods of no activity on MCB's. 1. How would the overall I²t losses, be affected with that arrangement?. 2. Would the maker concur with that arrangement as being necessary?. 3. Would the customer be paying for your design. 4. Would you advocate that arrangement for all C.U.'s. 5. Would you advocate others to follow suit. and the bottom line for dollars and sense - 6. Would it make you competitive? ?
Jaymack
Sparkingchip:
Jaymack:
Sparkingchip:
Andy Betteridge
Jaymack
Read some manufacturers instructions for installing MCBs which will be fully loaded for up to seven hours.
Andy Betteridge
Sparkingchip:
Try pegging the precise requirement down to determine exactly how many RCDs are required in a typical domestic installation.
Andy Betteridge
Jaymack:
Chris Pearson:
As it stands, the 32 A MCB is satisfactory.
What is now the current rating for a twin 13A socket outlet?.
Jaymack
